Uploading Sketches
When uploading a sketch my computer takes quite a while and displays the following message at the bottom of the window with the Ardunio program running:
Arduino: 1.8.1 (Windows 7), Board: "Arduino Duemilanove or Diecimila, ATmega328"
Sketch uses 1906 bytes (6%) of program storage space. Maximum is 30720 bytes.
Global variables use 55 bytes (2%) of dynamic memory, leaving 1993 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x0a
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x0a
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x0a
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x0a
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x0a
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x0a
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x0a
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x0a
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x0a
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x0a
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
I have installed the driver, checked that under tools < board, it was correct, and under tools < port the correct port has been selected. A boot-loader has already been burned onto the board. There is a green light labeled on and a blue blinking light on the red-board that are lit only when i connect the USB to my windows 7 computer. I have checked the code and am unable to find any errors. Why am I unable to upload the code?
