Hi I made a knightrider sketch with a pcf8574 this works well from the arduino uno but it is a small sketch so i thought of the attiny but uploading is a problem iam using TinyWireM.h from adafruit
#include <TinyWireM.h> // Software I2C voor ATtiny85
#define PCF8574_ADDR 0x20 // Standaard I2C-adres van PCF8574
TinyWireM.begin(); // Start softwarematige I2C
// LED van links naar rechts
for (int i = 0; i < 8; i++) {
TinyWireM.beginTransmission(PCF8574_ADDR);
TinyWireM.write(~(1 << i)); // Alleen LED i aan
TinyWireM.endTransmission();
delay(100);
// LED van rechts naar links
for (int i = 6; i > 0; i--) {
delay(100);
i think it is a small problem but i can use some help
Welcome to the forum
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
Please post your full sketch, using code tags when you do
Posting your code using code tags prevents parts of it being interpreted as HTML coding and makes it easier to copy for examination
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
It is also helpful to post error messages in code tags as it makes it easier to scroll through them and copy them for examination
i think i found it, there was a com port problem but with another arduino uno card the programming of the attiny was no problem
