Uploading telegram Message to MQTT.fx
#include <UniversalTelegramBot.h>
#include <EEPROM.h>
#include <PubSubClient.h>
#include <Wire.h>
#include <SoftwareSerial.h>    // Software Serial library
#include <ESP8266WiFi.h>
#include "NewPing.h"
#define ECHOPIN D1// Pin to receive echo pulse
#define TRIGPIN D2// Pin to send trigger pulse
#define MAX_DISTANCE 400 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
long Bot_lasttime;
NewPing sonar(TRIGPIN, ECHOPIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
long duration;        // declare duration as long. Long can store a bigger number than int.
int dist = 0; // declare distance as integer
int bulk_messages_mtbs = 1800000; // testing to delay 30 min to detecting another distance and which message been sent .
int bulk_messages2_mtbs = 36000; //testing to delay 6 sec to detecting bin been empty.
// Connect to the WiFi
const char* ssid = "";
const char* password = "";
// Connect to the MQTT Broker
const char* mqtt_server = "mosquitto.org";
const char* mqtt_username ="";
const char* mqtt_password = "";
const char* clientID = "MQTT_FX_Client";
// ------- Telegram config --------
#define BOT_TOKEN ""  // your Bot Token (Get from Botfather)
#define CHAT_ID "" // Chat ID of where you want the message to go (You can use MyIdBot to get the chat ID)
WiFiClient espClient;
PubSubClient client(espClient);
UniversalTelegramBot bot(BOT_TOKEN, Client);
String ipAddress = "";
volatile bool telegramButton1PressedFlag = false;
volatile bool telegramButton2PressedFlag = false;
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  for (int i = 0; i < length; i++) {
    char receivedChar = (char)payload[i];
    Serial.print(receivedChar);
    if (receivedChar == '0')
      digitalWrite(TRIGPIN, HIGH);
    if (receivedChar == '1')
      digitalWrite(ECHOPIN, LOW);
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.println("Attempting MQTT connection...");
    // Attempt to connect
    if (client.connect(clientID, mqtt_username, mqtt_password)) {
      Serial.println("Connected");
      // ... and subscribe to topic
      client.subscribe("MQTT_FX_Client/ZONE/#");
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
void setup(){
    client.setServer(mqtt_server, 1883);
    client.setCallback(callback);
    // initialize the button pin as a input:
    pinMode(ECHOPIN, INPUT);
    // initialize the LED as an output:
    pinMode(TRIGPIN, OUTPUT);
    // initialize serial communication:
// Connect to WiFinetwork
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    //Serial.begin(9600);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  // Start the server
  // server.begin();
  // Serial.println("Server started");
  // Print the IP address
  Serial.print("Local IP: ");
void telegramButton1Pressed() {
  Serial.println("Telegram Button-1 Pressed");
  int echo = digitalRead(D2);
  telegramButton1PressedFlag = true;
  return;
void sendTelegramMessage() {
  String message = "Shredder paper bin full, please clear it!";
  if(bot.sendMessage(CHAT_ID, message, "Markdown")){
    Serial.println("TELEGRAM Message  Successfully sent");
    client.publish("MQTT_FX_Client/ZONE/testzone", "Shredder paper bin full, please clear it!"); //
void telegramButton2Pressed() {
  Serial.println("Telegram Button-2 Pressed");
  return;
void sendTelegramMessage2(){
  String message2 = "Shredder paper bin cleared!";
  if(bot.sendMessage(CHAT_ID, message2, "Markdown")){
    Serial.println("TELEGRAM Message 2 Successfully sent");
    client.publish("MQTT_FX_Client/ZONE/testzone", "Shredder paper bin cleared!"); //
  dist = sonar.ping_cm();
  Serial.print(dist);
  Serial.println(" cm");
  delay(100);
  static bool dist_reach = false;
  if(dist <5) {
       Serial.println("Checking Full Condition again");
       delay(10000);       //delay 10 second for checking propose.
       if(!dist_reach)
          Serial.print(dist);
          delay(100);
          if(dist<5){
            Serial.println("sent notifcation1 to Telegram");
            sendTelegramMessage();
            delay(bulk_messages2_mtbs);
            Bot_lasttime = 0;
            dist_reach = true;
  else if (dist >60) {
             Serial.println("Checking Empty Condition again");
             delay(300000);     //delay 5 minutes for checking propose.
          if(dist_reach) {
                Serial.print(dist);
                delay(100);
                if(dist>60){
                   Serial.println("sent notifcation2 to Telegram");
                   sendTelegramMessage2();
                   Bot_lasttime = 0;
          dist_reach = false;
    if (!client.connected()) {
      reconnect();
    client.loop();
It shown the error message
777777:31:43: error: expected primary-expression before ')' token
exit status 1
option enabled in File -> Preferences.
The error is correct, the code is wrong there. "Client" is not defined there. There are many other such errors in the code.
pylon:
// SSL client needed for both libraries
WiFiClientSecure client;
UniversalTelegramBot bot(BOT_TOKEN, client);
yeah.This one my my starting code .That time i using WiFiClientSecure client; it can be work .After that i want added in mqtt.FX sever uploading to "mosquitto.org" because of
This two WiFiClient espClient; and PubSubClient client(espClient); cannot march with WiFiClientSercure client so i take away WiFiClientSercure and change to WiFiClient espClient; and PubSubClient client(espClient); then the problem is .Because internet not much document with telegram together with MQTT server so no information at all .
