Uploading to Arduino Nano ESP32 blocked
My arduino nano esp32 blocked .. no upload sketch and attach usb device change name other 10 name different ..
DF robot Esp32-C3, Dev Esp32 etc.. continue change name from serial port.
difficult upload sketch
Windows beep continue connect ,disconnect.
Hi, my name luigi from iitaly my english elementary .
Thanks.
Name usb from windows 11 22h2 64bit.
Hi, can you share the details of the core and the version number you are using?
Please make sure you are using the latest version of Arduino ESP32 Boards by Arduino.
My video from youtube.. my problem nano esp32 .. dopo il caricamento di un esempio che utilizzava il filesystem caricato via esptool tratto dall'esp32 normale.. come diceva sulle faq del sito arduino.cc che i codici andavano bene anche quelli dell'esp32 ..
invece mi pare di no.
Salve, e buon fine settimana.. scusa se ti scrivo in italiano.
Buona giornata.
Will the Nano ESP32 be compatible with sketches from generic ESP32 boards?
The Arduino Nano ESP32 can run code written for other ESP32 devices without any fuss. It's designed to be fully compatible with the ESP32 ecosystem, making it easy to port existing code.
Link:
Maybe you can give it a try to the following steps:
  1. select Arduino nano esp32 under the Tools/Board/esp32 menu
  2. Select the port under Tools/Port
  3. Make sure under Tools/Programmer, esptool is selected
  4. Go to Sketch and select Upload using programmer
  5. If the process is succesfull you will see "Hard reset using RST pin". Press the reset button
Let us know if this works
Non posso perché la porta USB non sta ferma e cambia sempre il nome e si connette e disconette sempre impossibile caricare altri ho fare un erase flash.
If there are connectivity problem, the first step is to try another usb cable and if possible give it a try in other computer.
Also can you describe the behaviour of the LEDs when the board is connected and when you double tap the reset button?
And if I understand correctly, the board changes names constantly, please install the core from Espressif by type esp32 in the board manager and try again even if the port changes, if it fails please share the console output
mi hanno risposto l'assistenza mi hanno detto che devo seguire questo
stasera provo e poi vi farò sapere. grazie mille e buona giornata.
Thanks 10000!!
Fixed Problem solved.
Congratulations!!
