Hello,
Im using arduino nano on my win10 64x.
I've been searching for a few days now for a solution and I will be forever grateful for every help that i can get.
I did everything as specified : chose the right board, the right processor and the right port.
I an not using a Chinese clone, but an original arduino. (checked it from the backside of the processor - FT232R)
I have installed the drive and opened IDE not through a shortcut. Tried pressing the reset button on the board, But nothing works.
strangely enough, if i try uploading something simple (blink for example) everything works fine.
If I enable the "show verbose output during output" option i notice that when uploading, the program gets stuck on "writing" - image attached.
In the end. I always get the same error message :
please help
I really don't know what else i can do...
Sketch uses 20538 bytes (66%) of program storage space. Maximum is 30720 bytes.
Global variables use 721 bytes (35%) of dynamic memory, leaving 1327 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b57600 -D -Uflash:w:C:\Users\Sagi\AppData\Local\Temp\arduino_build_524739/Blink.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 57600
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.16
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\Sagi\AppData\Local\Temp\arduino_build_524739/Blink.ino.hex"
avrdude: writing flash (20538 bytes):
Writing | ####avrdude: stk500_recv(): programmer is not responding
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
