Uploading to ATTINY85: Programmer is not responding
I'm using an Arudino Uno with the 1.6.4 IDE. I'm trying to upload a small sketch to an ATTINY85 and keep getting the error, programmer is not responding. I've tried the things mentioned in here, which included adding caps, checking for correct serial port, making sure settings are correct and I've made no progress. Here is a complete list of the errors:
Arduino: 1.6.5 (Windows 7), Board: "ATtiny, ATtiny85, 1 MHz (internal)"
Sketch uses 838 bytes (10%) of program storage space. Maximum is 8,192 bytes.
Global variables use 9 bytes of dynamic memory.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x03
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
  enabled in File > Preferences.
I'm could't get the bootloader to burn either as I got the same errors. Any other suggestions I might do?
