Hi everyone, I'm having a issue with a Sparkfun Pro Micro clone. I'm trying to upload the Joystick Test example in Arduino IDE . It seems to upload ok , in Device manager it appears as a USB Serial Device , shouldn't it be showing up as a HID device. This is the Joystick test.
// Program used to test the USB Joystick object on the
// Arduino Leonardo or Arduino Micro.
// Matthew Heironimus
// 2015-03-28 - Original Version
// 2015-11-18 - Updated to use the new Joystick library
// written for Arduino IDE Version 1.6.6 and
// above.
// 2016-05-13 Updated to use new dynamic Joystick library
// that can be customized.
// 2022-03-29 Updated to work with version 2.1.0 of the
// Joystick library.
#include "Joystick.h"
// Create Joystick
Joystick_ Joystick;
// Set to true to test "Auto Send" mode or false to test "Manual Send" mode.
//const bool testAutoSendMode = true;
const bool testAutoSendMode = false;
const unsigned long gcCycleDelta = 1000;
const unsigned long gcAnalogDelta = 25;
const unsigned long gcButtonDelta = 500;
unsigned long gNextTime = 0;
unsigned int gCurrentStep = 0;
void testSingleButtonPush(unsigned int button)
if (button > 0)
Joystick.releaseButton(button - 1);
if (button < 32)
Joystick.pressButton(button);
void testMultiButtonPush(unsigned int currentStep)
for (int button = 0; button < 32; button++)
if ((currentStep == 0) || (currentStep == 2))
if ((button % 2) == 0)
} else if (currentStep != 2)
Joystick.releaseButton(button);
} // if ((currentStep == 0) || (currentStep == 2))
if ((currentStep == 1) || (currentStep == 2))
if ((button % 2) != 0)
} // if ((currentStep == 1) || (currentStep == 2))
if (currentStep == 3)
} // if (currentStep == 3)
} // for (int button = 0; button < 32; button++)
void testXYAxis(unsigned int currentStep)
int xAxis;
int yAxis;
if (currentStep < 256)
xAxis = currentStep - 127;
yAxis = -127;
Joystick.setXAxis(xAxis);
Joystick.setYAxis(yAxis);
else if (currentStep < 512)
yAxis = currentStep - 256 - 127;
else if (currentStep < 768)
xAxis = 128 - (currentStep - 512);
else if (currentStep < 1024)
yAxis = 128 - (currentStep - 768);
else if (currentStep < 1024 + 128)
xAxis = currentStep - 1024 - 127;
Joystick.setYAxis(xAxis);
void testZAxis(unsigned int currentStep)
int z;
if (currentStep < 128)
z = -currentStep;
else if (currentStep < 256 + 128)
z = currentStep - 128 - 127;
else if (currentStep < 256 + 128 + 127)
z = 127 - (currentStep - 383);
Joystick.setZAxis(z);
void testHatSwitch(unsigned int currentStep)
if (currentStep < 8)
Joystick.setHatSwitch(0, currentStep * 45);
else if (currentStep == 8)
Joystick.setHatSwitch(0, -1);
else if (currentStep < 17)
Joystick.setHatSwitch(1, (currentStep - 9) * 45);
else if (currentStep == 17)
Joystick.setHatSwitch(1, -1);
else if (currentStep == 18)
Joystick.setHatSwitch(0, 0);
Joystick.setHatSwitch(1, 0);
else if (currentStep < 27)
Joystick.setHatSwitch(0, (currentStep - 18) * 45);
Joystick.setHatSwitch(1, (8 - (currentStep - 18)) * 45);
else if (currentStep == 27)
void testThrottleRudder(unsigned int value)
Joystick.setThrottle(value);
Joystick.setRudder(value);
void testXYZAxisRotation(unsigned int degree)
Joystick.setRxAxis(degree);
Joystick.setRyAxis(degree);
Joystick.setRzAxis(degree * 2);
// Set Range Values
Joystick.setXAxisRange(-127, 127);
Joystick.setYAxisRange(-127, 127);
Joystick.setZAxisRange(-127, 127);
Joystick.setRxAxisRange(0, 360);
Joystick.setRyAxisRange(360, 0);
Joystick.setRzAxisRange(0, 720);
Joystick.setThrottleRange(0, 255);
Joystick.setRudderRange(255, 0);
if (testAutoSendMode)
Joystick.begin();
Joystick.begin(false);
pinMode(A0, INPUT_PULLUP);
pinMode(LED_BUILTIN, OUTPUT);
// System Disabled
if (digitalRead(A0) != 0)
// Turn indicator light off.
digitalWrite(LED_BUILTIN, 0);
return;
// Turn indicator light on.
digitalWrite(LED_BUILTIN, 1);
if (millis() >= gNextTime)
if (gCurrentStep < 33)
gNextTime = millis() + gcButtonDelta;
testSingleButtonPush(gCurrentStep);
else if (gCurrentStep < 37)
testMultiButtonPush(gCurrentStep - 33);
else if (gCurrentStep < (37 + 256))
gNextTime = millis() + gcAnalogDelta;
testThrottleRudder(gCurrentStep - 37);
else if (gCurrentStep < (37 + 256 + 1024 + 128))
testXYAxis(gCurrentStep - (37 + 256));
else if (gCurrentStep < (37 + 256 + 1024 + 128 + 510))
testZAxis(gCurrentStep - (37 + 256 + 1024 + 128));
else if (gCurrentStep < (37 + 256 + 1024 + 128 + 510 + 28))
testHatSwitch(gCurrentStep - (37 + 256 + 1024 + 128 + 510));
else if (gCurrentStep < (37 + 256 + 1024 + 128 + 510 + 28 + 360))
testXYZAxisRotation(gCurrentStep - (37 + 256 + 1024 + 128 + 510 + 28));
if (testAutoSendMode == false)
Joystick.sendState();
gCurrentStep++;
if (gCurrentStep == (37 + 256 + 1024 + 128 + 510 + 28 + 360))
gNextTime = millis() + gcCycleDelta;
gCurrentStep = 0;
for some eason i can't copy and paste the verbose info from the successful upload , it says it verified the upload
