Uploading to Uno w/ Gentoo fails
I'm trying to get my Arduino Uno running with Gentoo (x86)
I installed arduino-0.21 and rxtx-2.2_pre2 from the overlay and avrdude-5.10 from portage.
The Power-LED is on, after Reset the L-Led flickers for about a second. Uno is selected in Boards, and /dev/ttyACM0 as Serial Controller.
Trying to upload the Blink-Expample I get:
Binary sketch size: 978 bytes (of a 32256 byte maximum)
/usr/share/arduino-0021/hardware/tools/avrdude -C/usr/share/arduino-0021/hardware/tools/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P/dev/ttyACM0 -b115200 -D -Uflash:w:/tmp/build7315047689847273776.tmp/Blink.cpp.hex:i
avrdude: Version 5.10, compiled on Mar  9 2011 at 13:03:13
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/usr/share/arduino-0021/hardware/tools/avrdude.conf"
         User configuration file is "/home/robelix/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyACM0
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 115200
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
         AVR Part                      : ATMEGA328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65     5     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [03]
avrdude: Send: A [41] . [81]   [20]
avrdude: Send: A [41] . [82]   [20]
avrdude: Send: A [41] . [98]   [20]
         Hardware Version: 3
         Firmware Version: 3.3
avrdude: Send: A [41] . [84]   [20]
avrdude: Send: A [41] . [85]   [20]
avrdude: Send: A [41] . [86]   [20]
avrdude: Send: A [41] . [87]   [20]
avrdude: Send: A [41] . [89]   [20]
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00]   [20]
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00]   [20]
avrdude: Send: P [50]   [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: V [56] 0 [30] . [00] . [00] . [00]   [20]
avrdude: Recv: . [00]
avrdude: Send: V [56] 0 [30] . [00] . [01] . [00]   [20]
################avrdude: Send: V [56] 0 [30] . [00] . [02] . [00]   [20]
################################## | 100% 0.01s
avrdude: Device signature = 0x000000
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
avrdude: Send: Q [51]   [20]
avrdude done.  Thank you.
TX and RX Leds are flickering while the upload is running.
When trying to write manually with -F there seems to be no error - but no Blinking ;(
What is going wrong?
Robelix
got it! - quite a hard start for a noob:
1) changed uno.upload.protocol in boards.conf from stk500 to arduino 2) hold reset, and release when upload starts 3) The Blink example does not blink. No idea why. But the BlinkWithoutDelay works.
I think the delay problems are caused by the version of avr-gcc you have. For some reason, 4.5.x seems to have this issue. You should try to use 4.3.x instead (4.3.2 or later).
I downgraded avr-gcc from 4.5.2 to 4.3.5 and avr-libc from 1.7.0 to 1.6.2 - but still the same: the Blink-Example does not Blink.
Downgrade / recompile avr-binutils to a version patched with Debian's avr-binutils patch set. (The bug seems to be in avr-ld)
Thank you stimmer!
binutils-2.20.1-r1 instead of 2.21 - and Blink finally blinks ;)
