Uploading troubles to 1284p
It didn't arrive, lol.
Well, you didn't say whose weekend, still have a small chance at getting it before My weekend - course, its going on 4:30pm, not much time left for UPS to make afternoon dropoffs ...
Chip arrived, got minimal board going. Details here:
Programming the bootloader:
Installing a sketch using the bootloader:
Good work nick... :slight_smile: Seems you to have got it working properly.. :slight_smile: Any troubles uploading til now?
I seem to have done all of these stuff mentioned earlier but still my problem still remains... :frowning: Anyways let me try doing it ditto as u mentioned in your tutorial...
@ nick
Tried uploading larger sketches? and Is the bootloader uploaded by your https://github.com/nickgammon/arduino_sketches/tree/master/Atmega_Board_Programmer same as the one provided by maniacbug?
Sorry Wrong link edited... :slight_smile:
Wow, that chip looks big in the first pic! Result of the camera angle I guess.
@nick
Freaking Hell!!! Ur bootloader hex file worked XD
did 10 uploads no troubles watsover.... :smiley: U are real life saver... :smiley: U solved the thing which was driving me nuts...
Did u change the bootloader?
One more thing... :slight_smile:
Now we'll install the bootloader upload sketch onto the Uno and run it (set the serial monitor to 115200 baud).
http://gammon.com.au/Arduino/Atmega_Board_Detector.zip
Plz edit the given link with the bootloader one in your tutorial page... :slight_smile:
000:
@ nick
Not yet.
and Is the bootloader uploaded by your arduino_sketches/Atmega_Board_Programmer at master · nickgammon/arduino_sketches · GitHub same as the one provided by maniacbug?
It is the file optiboot_atmega1284p.hex from maniacbug's GitHub page. Slightly modified to change some of the consecutive 0xFF bytes to be 0x00 because of the problem with uploading a lot of consecutive 0xFFs to the Uno using the standard Optiboot (known bug there).
000:
Fixed thx.
Strange. I expected more teething problems. :wink:
Well, glad it worked.
000:
Not apart from the change made so it would actually upload to the programming Uno.
@Nick Was comparing the chip fuse with maniacbugs (which I did earlier) and yours
Maniacbug
Atmega fuse calculator.
Written by Nick Gammon.
Entered programming mode OK.
Signature = 0x1E 0x97 0x05
Processor = ATmega1284P
Flash memory size = 262144
LFuse = 0xFF
HFuse = 0xDE
EFuse = 0xFD
Lock byte = 0xCF
OCD Enable.............................. [ ]
JTAG Enable............................. [ ]
Enable Serial (ICSP) Programming........ [X]
Watchdog Timer Always On................ [ ]
Preserve EEPROM through chip erase...... [ ]
Boot into bootloader.................... [X]
Divide clock by 8....................... [ ]
Clock output............................ [ ]
Bootloader size: 1024 bytes.
Start-up time: SUT0: [X]  SUT1: [X] (see datasheet)
Clock source: low-power crystal.
Brownout detection at: 2.7V.
Nicks Bootloader
Flash memory size = 131072
LFuse = 0xFF
HFuse = 0xDE
EFuse = 0xFD
Lock byte = 0xEF
Lock byte and Flash memory sizes are different..
Board detector output files Comparison
With Maniac bugs bootloader
Atmega chip detector.
Signature = 1E 97 05
LFuse = FF
HFuse = DE
EFuse = FD
Lock byte = CF
Bootloader in use: Yes
EEPROM preserved through erase: No
Watchdog timer always on: No
Bootloader is 1024 bytes starting at 3FC00
Bootloader:
3FC00: 0F 92 CD B7 DE B7 11 24 84 B7 14 BE 81 FF F1 D0
3FC10: 85 E0 80 93 81 00 82 E0 80 93 C0 00 88 E1 80 93
3FC20: C1 00 86 E0 80 93 C2 00 80 E1 80 93 C4 00 8E E0
3FC30: CA D0 20 9A 26 E0 80 E3 9C EF 31 E0 90 93 85 00
3FC40: 80 93 84 00 36 BB B0 9B FE CF 18 9A A8 95 21 50
3FC50: A9 F7 00 E0 10 E0 EE 24 E3 94 E1 E1 DE 2E F3 E0
3FC60: FF 2E A5 D0 81 34 71 F4 A2 D0 89 83 B2 D0 89 81
3FC70: 82 38 09 F4 8B C0 81 38 11 F4 84 E0 01 C0 83 E0
3FC80: 8F D0 8B C0 82 34 11 F4 84 E1 03 C0 85 34 19 F4
3FC90: 85 E0 A7 D0 82 C0 85 35 91 F4 89 D0 A8 2E BB 24
3FCA0: 86 D0 08 2F 10 E0 10 2F 00 27 0A 29 1B 29 81 2F
3FCB0: 88 1F 88 27 88 1F 8B BF 00 0F 11 1F 6D C0 86 35
3FCC0: 21 F4 84 E0 8E D0 80 E0 DB CF 84 36 09 F0 40 C0
3FCD0: 6E D0 6D D0 C8 2E 6B D0 80 EE 00 30 18 07 18 F4
3FCE0: F8 01 F7 BE E8 95 A1 2C 51 E0 B5 2E 60 D0 F5 01
3FCF0: 81 93 5F 01 CE 16 D1 F7 F0 EE 00 30 1F 07 18 F0
3FD00: F8 01 F7 BE E8 95 65 D0 07 B6 00 FC FD CF F8 01
3FD10: A0 E0 B1 E0 2C 91 30 E0 11 96 8C 91 11 97 90 E0
3FD20: 98 2F 88 27 82 2B 93 2B 12 96 0C 01 E7 BE E8 95
3FD30: 11 24 32 96 82 E0 A0 30 B8 07 61 F7 85 E0 F8 01
3FD40: 87 BF E8 95 07 B6 00 FC FD CF D7 BE E8 95 25 C0
3FD50: 84 37 A9 F4 2C D0 2B D0 B8 2E 29 D0 3A D0 CB 2C
3FD60: 48 01 F4 01 86 91 1C D0 08 94 81 1C 91 1C CA 94
3FD70: C1 F7 0F 5F 1F 4F BA 94 0B 0D 11 1D 0E C0 85 37
3FD80: 39 F4 27 D0 8E E1 0C D0 87 E9 0A D0 85 E0 78 CF
3FD90: 81 35 11 F4 88 E0 17 D0 1C D0 80 E1 01 D0 61 CF
3FDA0: 90 91 C0 00 95 FF FC CF 80 93 C6 00 08 95 80 91
3FDB0: C0 00 87 FF FC CF 80 91 C0 00 84 FD 01 C0 A8 95
3FDC0: 80 91 C6 00 08 95 E0 E6 F0 E0 98 E1 90 83 80 83
3FDD0: 08 95 ED DF 80 32 19 F0 88 E0 F5 DF FF CF 84 E1
3FDE0: DF CF CF 93 C8 2F E3 DF C1 50 E9 F7 F2 DF CF 91
3FDF0: 08 95 80 E0 E8 DF EE 27 FF 27 09 94 FF FF FF FF
3FE00: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FE10: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FE20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FE30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FE40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FE50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FE60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FE70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FE80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FE90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FEA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FEB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FEC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FED0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FEE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FEF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FF00: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FF10: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FF20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FF30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FF40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FF50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FF60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FF70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FF80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FF90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FFA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FFB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FFC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FFD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FFE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
3FFF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
MD5 sum of bootloader = 71 DD C2 84 64 C4 73 27 D2 33 01 1E FA E1 24 4B
First 256 bytes of program memory:
0: 0C 94 87 00 0C 94 B2 00 0C 94 B2 00 0C 94 B2 00
10: 0C 94 B2 00 0C 94 B2 00 0C 94 B2 00 0C 94 B2 00
20: 0C 94 B2 00 0C 94 B2 00 0C 94 B2 00 0C 94 B2 00
30: 0C 94 B2 00 0C 94 B2 00 0C 94 B2 00 0C 94 B2 00
40: 0C 94 B2 00 0C 94 B2 00 0C 94 7B 12 0C 94 B2 00
50: 0C 94 66 14 0C 94 FC 14 0C 94 B2 00 0C 94 B2 00
60: 0C 94 B2 00 0C 94 B2 00 0C 94 B2 00 0C 94 B2 00
70: 0C 94 9F 14 0C 94 49 15 0C 94 B2 00 0C 94 B2 00
80: 0C 94 B2 00 0C 94 B2 00 0C 94 B2 00 00 00 21 00
90: 24 00 27 00 2A 00 00 00 22 00 25 00 28 00 2B 00
A0: 00 00 20 00 23 00 26 00 29 00 02 02 02 02 02 02
B0: 02 02 04 04 04 04 04 04 04 04 03 03 03 03 03 03
C0: 03 03 01 01 01 01 01 01 01 01 01 02 04 08 10 20
D0: 40 80 01 02 04 08 10 20 40 80 01 02 04 08 10 20
E0: 40 80 01 02 04 08 10 20 40 80 00 00 00 01 02 00
F0: 08 09 00 00 00 00 04 03 07 06 00 00 00 00 00 00
continued onto next post (Char limit) :slight_smile:
And Nicks bootloader (Working..)
LFuse = FF
HFuse = DE
EFuse = FD
Lock byte = EF
Bootloader is 1024 bytes starting at 1FC00
Bootloader:
1FC00: 0F 92 CD B7 DE B7 11 24 84 B7 14 BE 81 FF F1 D0
1FC10: 85 E0 80 93 81 00 82 E0 80 93 C0 00 88 E1 80 93
1FC20: C1 00 86 E0 80 93 C2 00 80 E1 80 93 C4 00 8E E0
1FC30: CA D0 20 9A 26 E0 80 E3 9C EF 31 E0 90 93 85 00
1FC40: 80 93 84 00 36 BB B0 9B FE CF 18 9A A8 95 21 50
1FC50: A9 F7 00 E0 10 E0 EE 24 E3 94 E1 E1 DE 2E F3 E0
1FC60: FF 2E A5 D0 81 34 71 F4 A2 D0 89 83 B2 D0 89 81
1FC70: 82 38 09 F4 8B C0 81 38 11 F4 84 E0 01 C0 83 E0
1FC80: 8F D0 8B C0 82 34 11 F4 84 E1 03 C0 85 34 19 F4
1FC90: 85 E0 A7 D0 82 C0 85 35 91 F4 89 D0 A8 2E BB 24
1FCA0: 86 D0 08 2F 10 E0 10 2F 00 27 0A 29 1B 29 81 2F
1FCB0: 88 1F 88 27 88 1F 8B BF 00 0F 11 1F 6D C0 86 35
1FCC0: 21 F4 84 E0 8E D0 80 E0 DB CF 84 36 09 F0 40 C0
1FCD0: 6E D0 6D D0 C8 2E 6B D0 80 EE 00 30 18 07 18 F4
1FCE0: F8 01 F7 BE E8 95 A1 2C 51 E0 B5 2E 60 D0 F5 01
1FCF0: 81 93 5F 01 CE 16 D1 F7 F0 EE 00 30 1F 07 18 F0
1FD00: F8 01 F7 BE E8 95 65 D0 07 B6 00 FC FD CF F8 01
1FD10: A0 E0 B1 E0 2C 91 30 E0 11 96 8C 91 11 97 90 E0
1FD20: 98 2F 88 27 82 2B 93 2B 12 96 0C 01 E7 BE E8 95
1FD30: 11 24 32 96 82 E0 A0 30 B8 07 61 F7 85 E0 F8 01
1FD40: 87 BF E8 95 07 B6 00 FC FD CF D7 BE E8 95 25 C0
1FD50: 84 37 A9 F4 2C D0 2B D0 B8 2E 29 D0 3A D0 CB 2C
1FD60: 48 01 F4 01 86 91 1C D0 08 94 81 1C 91 1C CA 94
1FD70: C1 F7 0F 5F 1F 4F BA 94 0B 0D 11 1D 0E C0 85 37
1FD80: 39 F4 27 D0 8E E1 0C D0 87 E9 0A D0 85 E0 78 CF
1FD90: 81 35 11 F4 88 E0 17 D0 1C D0 80 E1 01 D0 61 CF
1FDA0: 90 91 C0 00 95 FF FC CF 80 93 C6 00 08 95 80 91
1FDB0: C0 00 87 FF FC CF 80 91 C0 00 84 FD 01 C0 A8 95
1FDC0: 80 91 C6 00 08 95 E0 E6 F0 E0 98 E1 90 83 80 83
1FDD0: 08 95 ED DF 80 32 19 F0 88 E0 F5 DF FF CF 84 E1
1FDE0: DF CF CF 93 C8 2F E3 DF C1 50 E9 F7 F2 DF CF 91
1FDF0: 08 95 80 E0 E8 DF EE 27 FF 27 09 94 FF FF FF FF
1FE00: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FE10: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FE20: 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FE30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FE40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FE50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FE60: 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FE70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FE80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FE90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FEA0: 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FEB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FEC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FED0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FEE0: 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FEF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FF00: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FF10: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FF20: 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FF30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FF40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FF50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FF60: 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FF70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FF80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FF90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FFA0: 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FFB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FFC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FFD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FFE0: 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1FFF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
MD5 sum of bootloader = 77 2F 81 F1 7F 1E 46 93 97 B4 54 23 4C 44 72 68
0: 0C 94 85 00 0C 94 A5 00 0C 94 A5 00 0C 94 A5 00
10: 0C 94 A5 00 0C 94 A5 00 0C 94 A5 00 0C 94 A5 00
20: 0C 94 A5 00 0C 94 A5 00 0C 94 A5 00 0C 94 A5 00
30: 0C 94 A5 00 0C 94 A5 00 0C 94 A5 00 0C 94 A5 00
40: 0C 94 A5 00 0C 94 A5 00 0C 94 C1 00 0C 94 A5 00
50: 0C 94 A5 00 0C 94 A5 00 0C 94 A5 00 0C 94 A5 00
60: 0C 94 A5 00 0C 94 A5 00 0C 94 A5 00 0C 94 A5 00
70: 0C 94 A5 00 0C 94 A5 00 0C 94 A5 00 0C 94 A5 00
80: 0C 94 A5 00 0C 94 A5 00 0C 94 A5 00 00 00 21 00
Maybe this was the problem?? or Fuse settings difference was also there in Lock byte and Flash memory sizes :slight_smile:
000:
I had a bug in my sketches (now corrected) where it thought the 1284 had 256 Kb of memory. Of course, it has 128 Kb of memory. So that is just a bug on my part.
The lock bits aren't that important (well, they are important) but the difference shouldn't affect uploading. I just turned on the bit which lets the sketch read the memory of the bootloader.
Come to think of it, I found a rogue line in maniacbug's bootloader, which I deleted:
:020000000504F5  <----- delete this line
:020000021000EC
:10FC00000F92CDB7DEB7112484B714BE81FFF1D0B7
:10FC100085E08093810082E08093C00088E180933A
:10FC2000C10086E08093C20080E18093C4008EE032
:10FC3000CAD0209A26E080E39CEF31E090938500C3
:10FC40008093840036BBB09BFECF189AA8952150B4
:10FC5000A9F700E010E0EE24E394E1E1DE2EF3E00A
:10FC6000FF2EA5D0813471F4A2D08983B2D08981CE
:10FC7000823809F48BC0813811F484E001C083E03C
:10FC80008FD08BC0823411F484E103C0853419F421
:10FC900085E0A7D082C0853591F489D0A82EBB24F9
:10FCA00086D0082F10E0102F00270A291B29812F4A
:10FCB000881F8827881F8BBF000F111F6DC08635D6
:10FCC00021F484E08ED080E0DBCF843609F040C0A0
:10FCD0006ED06DD0C82E6BD080EE0030180718F4AF
:10FCE000F801F7BEE895A12C51E0B52E60D0F501E2
:10FCF00081935F01CE16D1F7F0EE00301F0718F0A8
:10FD0000F801F7BEE89565D007B600FCFDCFF80115
:10FD1000A0E0B1E02C9130E011968C91119790E029
:10FD2000982F8827822B932B12960C01E7BEE8951B
:10FD30001124329682E0A030B80761F785E0F8011F
:10FD400087BFE89507B600FCFDCFD7BEE89525C074
:10FD50008437A9F42CD02BD0B82E29D03AD0CB2C74
:10FD60004801F40186911CD00894811C911CCA940E
:10FD7000C1F70F5F1F4FBA940B0D111D0EC08537D1
:10FD800039F427D08EE10CD087E90AD085E078CF0E
:10FD9000813511F488E017D01CD080E101D061CF0B
:10FDA0009091C00095FFFCCF8093C600089580918C
:10FDB000C00087FFFCCF8091C00084FD01C0A895E2
:10FDC0008091C6000895E0E6F0E098E1908380839A
:10FDD0000895EDDF803219F088E0F5DFFFCF84E190
:10FDE000DFCFCF93C82FE3DFC150E9F7F2DFCF9128
:0CFDF000089580E0E8DFEE27FF2709946B
:040000031000FC00ED
:00000001FF
I couldn't see the point of that, so that was the only real change I made.
Oh yes, and the changes to the 0xFF I mentioned, are really an artifact of my conversion process. They weren't in the original bootloader file anyway.
@ Nick that could have been the problem I guess... Anyways mine is working nicely now... :smiley: Thanks a lot again...
@ All I would suggest Nick hex file for bootloaders on ATmega1284p :slight_smile:
Oh... God!!! Why me??? =( The issue is back... :frowning:
avrdude: stk500_getsync(): not in sync: resp=0x00
and I am back to square one... :frowning:
It was fun while it worked... :frowning:
We seem to have more than one issue here. On the one hand, the bootloader uploader worked.
On the other, your particular installations seems a bit flaky.
To save me re-reading 4 or 5 pages, can you just remind me of your hardware setup? Or take a photo, preferably?
Idiot... I am an idiot... found the problem I forgot to change the boards to Atmega1284 in IDE last time I uploaded. thats why this time I got sync errors... I was toggling between Duemolanove and Atmega1284 so last time I forgot to change it back... SO new bootloader has actually solved the problem... :smiley: I am so relieved now!!! :smiley:
Thanx again for Nick and Crossroads for your helps... :slight_smile:
Woo hoo!
This is the boot code version number. I think it is not supposed to be at that location. See optiboot.c and the Makefile: the version is meant to be in a section named "version".
All targets in the optiboot makefile that do not specify -DBIGBOOT have an option like this in the LDSECTIONS variable:
   -Wl,--section-start=.text=0x7e00  -Wl,--section-start=.version=0x7ffe
which makes the version section start 2 bytes before the end of the 512 byte range in which the bootloader should fit.
For some reason the big bootloaders do not have this option.
I added such an option for the atmega1284:
atmega1284: LDSECTIONS = -Wl,--section-start=.text=0x1fc00 -Wl,--section-start=.version=0x1fffe
(version section starts at the end of the 1024 bytes in which the big bootloader should fit)
If I make the bootloader again, the version number ends up nicely at address 1FFFE and the hex file looks like this:
:020000021000EC
:10FC0000112484B714BE81FFF3D085E08093810076
:10FDE0001F93182FE3DF1150E9F7F2DF1F910895F9
:0AFDF00080E0E8DFEE27FF2709940A
:02FFFE000504F8
:040000031000FC00ED
:00000001FF
(I did not post the complete hex as all byte are different from the original hex file and I have no 1284 to test this)
