core.a(main.cpp.o): In function main':
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/main.cpp:7: undefined reference tosetup'
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/main.cpp:10: undefined reference to `loop'
Please, anyone has had the same problem?
thanks a lot
marco
when i upload an example, “blink” in this case, the response
i have is this:
Binary sketch size: 1018 bytes (of a 32256 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x86
i have installed and uninstalled and again the drivers, but nothing happens. the card is seen from IDE.
i run IDE on mac os x 10.4.11 (PPC)
thanks in advance for your time
marco
Binary sketch size: 1252 bytes (of a 32256 byte maximum)
i've checked the network system panel, ok;
the port, ok; the selection of the board, ok;
the drivers (also if with arduino uno you don't need
these); the string in serial monitor recognize the
board (also if only at the proper speed of the internal
modem: internal 56k)....
any ideas?
could be that UNO works just with new OSX, let's say 10.5 or later?
anybody are using a UNO board with an OSX older than 10.5??
thanx
m.
