Hello..i am new to the arduino world.. I just want to know , right now i'm working on data logging to pachube.com using GPRS .For the moment I only want to submit temperature data to my pachube.com , and I read about this at http://seeedstudio.com/wiki/GPRS_Shield#Uploading_Sensor_Data_to_Pachube.com_using_GPRS ..I try adjust the codes there , as I want to submit only one data per time I will not use any SD card to store the data,so I adjust the code like below:
my equipment is:
1 lm35
1 arduino duemilanove
1 SIM900 GSM/GPRS MODULE
really, it is a simple project,but ,I'm new to this,and I cant detect any error to the following code,so please guys I am eager to know, why I cant get any reading at my pachube account.The serial terminal said my data succesfully sent,but I dont receive anything at all at my pachube account here https://pachube.com/feeds/55223 . If you have any alternative code,do you mind sharing.Because I keep looking on the internet , and no one write a good code based on GPRS module to pachube.com . I nearly giveup because not a lot of people know pachube.com . I might consider to offer $us10 for helping me ,with the code.I am no programmer,so I got dizzy when something like this happen. I study myself the AT command but I dont understand half of it. I do not know any expert.Help me please ![]()
my circuit connection as below :
and LM35 is at analog input 0
#include <NewSoftSerial.h>
#include "FileLogger.h"float tempC;
int tempPin = 0;NewSoftSerial GPRS_Serial(6, 4);
GPRS_Serial.begin(9600); //GPRS Shield baud rate
Serial.begin(9600);setup_start:
Serial.println("Turn on GPRS Modem and wait for 1 minute.");
Serial.println("and then press a key");
Serial.println("Press c for power on configuration");
Serial.println("press any other key for uploading");
Serial.flush();
while(Serial.available() == 0);
if(Serial.read()=='c')
Serial.println("Executing AT Commands for one time power on configuration");GPRS_Serial.flush();
GPRS_Serial.println("ATE0"); //Command echo off
Serial.println("ATE0 Sent");
if(GPRS_Serial_wait_for_bytes(4,10) == 0)
Serial.println("Timeout");
goto setup_start;
Serial.print("Received:");
while(GPRS_Serial.available()!=0)
Serial.print((unsigned char)GPRS_Serial.read());
Serial.print("\n");
}GPRS_Serial.println("AT+CIPMUX=0"); //We only want a single IP Connection at a time.
Serial.println("AT+CIPMUX=0 Sent");
goto setup_start;
Serial.print("\n");
}GPRS_Serial.println("AT+CIPMODE=0"); //Selecting "Normal Mode" and NOT "Transparent Mode" as the TCP/IP Application Mode
Serial.println("AT+CIPMODE=0 Sent!");
goto setup_start;
Serial.print("\n");
}GPRS_Serial.println("AT+CGDCONT=1,"192.168.1.23","celcom3g","203.82.64.41",0,0"); //Defining the Packet Data
//Protocol Context - i.e. the Protocol Type, Access Point Name and IP Address
Serial.println("AT+CGDCONT=1,"192.168.1.23","celcom3g","203.82.64.41",0,0 Sent!");
goto setup_start;
Serial.print("\n");
}GPRS_Serial.println("AT+CSTT="celcom3g""); //Start Task and set Access Point Name (and username and password if any)
Serial.println("AT+CSTT="celcom3g" Sent!");
goto setup_start;
Serial.print("\n");
}GPRS_Serial.println("AT+CIPSHUT"); //Close any GPRS Connection if open
Serial.println("AT+CIPSHUT Sent!");
if(GPRS_Serial_wait_for_bytes(7,10) == 0)
goto setup_start;
Serial.print("\n");
}void loop()
tempC = analogRead(tempPin); //read the value from the sensor
tempC = (5.0 * tempC * 100.0)/1024.0; //convert the analog data to temperature
Serial.print((byte)tempC); //send the data to the computer
delay(1000);loop_start:
Serial.println("Press a key to read temperature and upload it");
Serial.flush();
Serial.read();Serial.print("Temperature = ");
Serial.println(tempC);GPRS_Serial.println("AT+CIPSTART="TCP","api.pachube.com","80""); //Open a connection to Pachube.com
Serial.println("AT+CIPSTART="TCP","api.pachube.com","80" Sent!");
if(GPRS_Serial_wait_for_bytes(12,255) == 0)
goto loop_start;
Serial.print("\n");
}GPRS_Serial.flush();
GPRS_Serial.println("AT+CIPSEND"); //Start data through TCP connection
Serial.println("AT+CIPSEND Sent!");
if(GPRS_Serial_wait_for_bytes(1,100) == 0)
goto loop_start;
Serial.print("\n");
//Emulate HTTP and use PUT command to upload temperature datapoint using Comma Seperate Value Method
GPRS_Serial.print("PUT /v2/feeds/55223.csv .csv HTTP/1.1\r\n");
Serial.println("PUT /v2/feeds/55223.csv HTTP/1.1 Sent!");
delay(300);GPRS_Serial.print("Host: api.pachube.com\r\n");
Serial.println("Host: api.pachube.com Sent!");
delay(300);GPRS_Serial.print("X-PachubeApiKey: my api key \r\n"); //REPLACE THIS KEY WITH YOUR OWN PACHUBE API KEY
Serial.println("X-PachubeApiKey: my Api key Sent!"); //REPLACE THIS KEY WITH YOUR OWN PACHUBE API KEY
delay(300);GPRS_Serial.print("Content-Length: 12\r\n");
Serial.print("Content-Length: 12 Sent!");
delay(300);GPRS_Serial.print("Connection: close\r\n\r\n");
Serial.print("Connection: close Sent!");
delay(300);
GPRS_Serial.print("TEMP,"); //You may replace the stream name "TMP102" to any other string that you have choosen.
delay(300);
GPRS_Serial.print(tempC);
delay(300);
GPRS_Serial.print("\r\n");
delay(300);
delay(300);
GPRS_Serial.print(0x1A,BYTE);
delay(300); //Send End Of Line Character to send all the data and close connection
if(GPRS_Serial_wait_for_bytes(20,255) == 0)
goto loop_start;
Serial.print("\n");
GPRS_Serial.println("AT+CIPSHUT"); //Close the GPRS Connection
if(GPRS_Serial_wait_for_bytes(4,100) == 0)
goto loop_start;
Serial.print("\n");
}char GPRS_Serial_wait_for_bytes(char no_of_bytes, int timeout)
while(GPRS_Serial.available() < no_of_bytes)
delay(200);
timeout-=1;
if(timeout == 0)
return 0;
return 1;
