I'm NOT a newbie!
I have uploaded the blink sketch with printouts and NOTHING happens after successful upload. Here's the info from uploader.
how is this possible.
Leaving...
TRACE +0.010 command op=0x02 data len=16 wait_response=1 timeout=3.000 data=00000000000000000040000000000000
TRACE +0.000 Write 26 bytes:
c000021000000000 0000000000000000 | ................
0000400000000000 00c0 | ..@.......
TRACE +0.003 Read 1 bytes: c0
TRACE +0.001 Read 1 bytes: 01
TRACE +0.000 Read 10 bytes: 020200000000000000c0
TRACE +0.000 Received full packet: 01020200000000000000
TRACE +0.012 command op=0x12 data len=4 wait_response=1 timeout=3.000 data=01000000
TRACE +0.000 Write 14 bytes: c0001204000000000001000000c0
TRACE +0.002 Read 1 bytes: c0
TRACE +0.000 Read 10 bytes: 120200000000000000c0
TRACE +0.000 Received full packet: 01120200000000000000
Hard resetting via RTS pin...
// the setup function runs once when you press reset or power the board
// initialize digital pin 0 as an output.
pinMode(0, OUTPUT);
Serial.println("setting up");
// the loop function runs over and over again forever
Serial.println("on");
digitalWrite(0, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
Serial.println("off");
digitalWrite(0, LOW); // turn the LED off by making the voltage LOW
