Uploaing error to arduino nano 33 BLE sense
hi i am trying to upload my code to arduino nano 33 BLE sense. but it gives the following error:
Sketch uses 85280 bytes (8%) of program storage space. Maximum is 983040 bytes.
Global variables use 44560 bytes (16%) of dynamic memory, leaving 217584 bytes for local variables. Maximum is 262144 bytes.
No device found on COM9
Failed uploading: uploading error: exit status 1
at first a tried to slected 'Arduino nano 33 BLE sense' board but it didnt accept. it didn't install. so i selected the other option 'Arduino nao 33 BLE'
but it does not upload. it gives the same error messages: "no device found on port x" or "device is unsuported"
Hi @gildesio welcome to the forum.
You might want to look at this How to get the best out of this forum before you proceed any further.
We only know what you tell us, and without knowing what you have, we don't stand a chance.
So in your case we need to know what code you are trying to run and on what board. That link will tell you how to post code on this forum.
Install IDE 2 with all the dependencies that show up after the installation, use a good data cable to connect your board to the PC (very important) and then double tap the reset button fast and upload blink LED sketch to the board. You should follow this guide Getting started with the Arduino Nano 33 BLE Sense
i did as instructed but it still didn't work
Contact Arduino Support via Contact us
with details of the issue and your purchase receipt.
thank you.
now i am trying to appload a modified code with the same goal to my project (AI audio Classifier smartbin) on ESP32-C3. in this i include the library for i2s but i am having this error:
C:\Users\user\AppData\Local\Temp.arduinoIDE-unsaved202464-15228-341imb.qbvlj\sketch_jul4a\sketch_jul4a.ino:2:10: fatal error: driver/i2s.h: No such file or directory
#include <driver/i2s.h>
compilation terminated.
exit status 1
Compilation error: driver/i2s.h: No such file or directory
i have installed ESP32 libraries but still getting this error message
You still haven't told us anything relevant. Why is that?
i want to know how to install libraries for i2s
i intend to upload the code to a ESP32-C3 board. the objective of this code is to command the arduino to give input to a servo motor, stepper motor, ultrasonic sensor, to build an AI audio classifier smart dust bin.
#include <Arduino.h>
#include <AccelStepper.h>
#include <ESP32Servo.h> // Library for Servo motor on ESP32
#include <Edge_AI_Recycle_Bin_inferencing.h>
/** Audio buffers, pointers and selectors */
typedef struct {
    int16_t *buffer;
    uint8_t buf_ready;
    uint32_t buf_count;
    uint32_t n_samples;
} inference_t;
static inference_t inference;
static int16_t sampleBuffer[2048];
static bool debug_nn = false; // Set this to true to see e.g. features generated from the raw signal
AccelStepper stepper1(1, 2, 3); // Adjust pins as needed for your stepper motor
Servo trapdoor; // Servo motor object for ESP32
const int HALL = 5; // Hall sensor pin
int compartment[] = {925, 2775, 0, 4625, 6475}; // Compartment positions based on model (Bottle, Can, Noise, Paper, Ping-pong)
float threshold = 0.8;
int selected = 2; // Default as Noise
void setupI2SMicrophone() {
    i2s_config_t i2s_config = {
        .mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_RX),
        .sample_rate = 16000,
        .bits_per_sample = I2S_BITS_PER_SAMPLE_16BIT,
        .channel_format = I2S_CHANNEL_FMT_ONLY_LEFT,
        .communication_format = I2S_COMM_FORMAT_I2S,
        .intr_alloc_flags = ESP_INTR_FLAG_LEVEL1,
        .dma_buf_count = 4,
        .dma_buf_len = 1024,
        .use_apll = false,
        .tx_desc_auto_clear = false,
        .fixed_mclk = 0
    i2s_pin_config_t pin_config = {
        .bck_io_num = 25, // Adjust pins as needed
        .ws_io_num = 32,  // Adjust pins as needed
        .data_out_num = I2S_PIN_NO_CHANGE,
        .data_in_num = 33   // Adjust pins as needed
    i2s_driver_install(I2S_NUM_0, &i2s_config, 0, NULL);
    i2s_set_pin(I2S_NUM_0, &pin_config);
    i2s_zero_dma_buffer(I2S_NUM_0);
    pinMode(HALL, INPUT);
    trapdoor.attach(A5); // Attach servo to pin A5
    // Stepper motor calibration
    stepper1.setMaxSpeed(2000); // Set maximum speed value for the stepper
    stepper1.setAcceleration(1000); // Set acceleration value for the stepper
    while(digitalRead(HALL)){
      stepper1.setSpeed(-400); // Set the current position to 0 steps
      stepper1.runSpeed();
      Serial.println("Homing...");
    delay(100);
    stepper1.setCurrentPosition(0);
    // End of stepper motor calibration
    // Servo motor calibration
    for (int pos = 11; pos <= 90; pos += 1) { // Goes from 0 degrees to 180 degrees in steps of 1 degree
        trapdoor.write(pos); // Tell servo to go to position in variable 'pos'
        delay(20); // Waits 20 ms for the servo to reach the position
    for (int pos = 90; pos >= 11; pos -= 1) { // Goes from 180 degrees to 0 degrees in steps of -1 degree
    delay(500); // Delay so the sound of servo is not captured
    Serial.println("Edge Impulse Inferencing Demo");
    // Summary of inferencing settings
    ei_printf("Inferencing settings:\n");
    ei_printf("\tInterval: %.2f ms.\n", (float)EI_CLASSIFIER_INTERVAL_MS);
    ei_printf("\tFrame size: %d\n", EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE);
    ei_printf("\tSample length: %d ms.\n", EI_CLASSIFIER_RAW_SAMPLE_COUNT / 16);
    ei_printf("\tNo. of classes: %d\n", sizeof(ei_classifier_inferencing_categories) / sizeof(ei_classifier_inferencing_categories[0]));
    if (!microphone_inference_start(EI_CLASSIFIER_RAW_SAMPLE_COUNT)) {
        ei_printf("ERR: Could not allocate audio buffer (size %d), this could be due to the window length of your model\r\n", EI_CLASSIFIER_RAW_SAMPLE_COUNT);
        return;
void captureAudio() {
    size_t bytesRead;
    i2s_read(I2S_NUM_0, &sampleBuffer, sizeof(sampleBuffer), &bytesRead, portMAX_DELAY);
    // Process the audio samples and run inference
static int microphone_audio_signal_get_data(size_t offset, size_t length, float *out_ptr) {
    for (size_t i = 0; i < length; i++) {
        out_ptr[i] = (float)sampleBuffer[offset + i] / 32768.0f;
    return 0;
    captureAudio();
    signal_t signal;
    signal.total_length = sizeof(sampleBuffer) / sizeof(sampleBuffer[0]);
    signal.get_data = &microphone_audio_signal_get_data;
    ei_impulse_result_t result = { 0 };
    EI_IMPULSE_ERROR r = run_classifier(&signal, &result, debug_nn);
    if (r != EI_IMPULSE_OK) {
        ei_printf("ERR: Failed to run classifier (%d)\n", r);
        return;
    // Print the predictions
    ei_printf("Predictions ");
    ei_printf("(DSP: %d ms., Classification: %d ms., Anomaly: %d ms.)",
        result.timing.dsp, result.timing.classification, result.timing.anomaly);
    ei_printf(": \n");
    for (size_t ix = 0; ix < EI_CLASSIFIER_LABEL_COUNT; ix++) {
        ei_printf("    %s: %.5f\n", result.classification[ix].label, result.classification[ix].value);
        if (result.classification[ix].value > threshold){
            ei_printf("\nYOUR TRASH IS: %s\n", result.classification[ix].label);
            selected = ix;
    // Control stepper motor and servo based on classification
    if (selected >= 0 && selected < sizeof(compartment) / sizeof(compartment[0])) {
        stepper1.moveTo(compartment[selected]);
        stepper1.runToPosition();
        delay(500); // Delay after action
#if EI_CLASSIFIER_HAS_ANOMALY == 1
    ei_printf("    anomaly score: %.3f\n", result.anomaly);
#endif
static bool microphone_inference_start(uint32_t n_samples) {
    inference.buffer = (int16_t *)malloc(n_samples * sizeof(int16_t));
    if (inference.buffer == NULL) {
        return false;
    inference.buf_count  = 0;
    inference.n_samples  = n_samples;
    inference.buf_ready  = 0;
    // Configure the data receive callback
    PDM.onReceive(&pdm_data_ready_inference_callback);
    PDM.setBufferSize(4096);
    // Initialize PDM with:
    // - one channel (mono mode)
    // - a 16 kHz sample rate
    if (!PDM.begin(1, EI_CLASSIFIER_FREQUENCY)) {
        ei_printf("Failed to start PDM!");
        microphone_inference_end();
        return false;
    // Set the gain, defaults to 20
    PDM.setGain(80);
    return true;
static void pdm_data_ready_inference_callback(void) {
    int bytesAvailable = PDM.available();
    int bytesRead = PDM.read((char *)&sampleBuffer[0], bytesAvailable);
    if (inference.buf_ready == 0) {
        for (int i = 0; i < bytesRead >> 1; i++) {
            inference.buffer[inference.buf_count++] = sampleBuffer[i];
            if (inference.buf_count >= inference.n_samples) {
                inference.buf_ready = 1;
static bool microphone_inference_record(void) {
    return true;
static void microphone_inference_end(void) {
    free(inference.buffer);
    inference.buffer = NULL;
i have got this new code for ESP32-C3 (i didn't get to use the nano 33 BLE sense, tried every thing until i gave up-The code was compiling though) and i am having errors while trying to compile it. i need help to correcting the code. this is my first time dealing with this
