This code is supposed to calculate volume based on user input to the key pad but after pressing the "#" key the flowmeter stops registering values in the serial monitor.
#include <LiquidCrystal.h> //include LCD library (standard library)
#include <Keypad.h> //include keypad library - first you must install library (library link in the video description)
const byte rows = 4; //number of the keypad's rows and columns
const byte cols = 4;
char keyMap [rows] [cols] = { //define the cymbols on the buttons of the keypad
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
byte rowPins [rows] = {3, 4, 5, 6}; //pins of the keypad
byte colPins [cols] = {7, 8, 9, 10};
byte statusLed = 13;
byte sensorInterrupt = 0; // 0 = digital pin 2
byte sensorPin = 2;
// The hall-effect flow sensor outputs approximately 4.5 pulses per second per
// litre/minute of flow.
float calibrationFactor = 7.5;
volatile byte pulseCount;
float flowRate;
unsigned int flowMilliLitres;
unsigned long totalMilliLitres;
unsigned long oldTime;
void pulseCounter()
// Increment the pulse counter
pulseCount++;
long Num1,Number;
char key,action;
boolean result = false;
float constant = 0.623;
Keypad myKeypad = Keypad( makeKeymap(keyMap), rowPins, colPins, rows, cols);
LiquidCrystal lcd(A0, A1, A2, A3, A4, A5);
byte raindrop[8] = {
0b00100,
0b00100,
0b01110,
0b01110,
0b11111,
0b11111,
0b11111,
0b01110
lcd.begin(16, 2);
lcd.createChar(0, raindrop);
lcd.setCursor(2, 0);
lcd.write(byte(0));
lcd.print("WaterRight");
lcd.write(byte(0));
delay(2000);
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Enter Area:");
Serial.begin(38400); //start of flow meter code
// Set up the status LED line as an output
pinMode(statusLed, OUTPUT);
digitalWrite(statusLed, HIGH); // We have an active-low LED attached
pinMode(sensorPin, INPUT);
digitalWrite(sensorPin, HIGH);
pulseCount = 0;
flowRate = 0.0;
flowMilliLitres = 0;
totalMilliLitres = 0;
oldTime = 0;
// The Hall-effect sensor is connected to pin 2 which uses interrupt 0.
// Configured to trigger on a FALLING state change (transition from HIGH
// state to LOW state)
attachInterrupt(sensorInterrupt, pulseCounter, FALLING);
key = myKeypad.getKey(); //storing pressed key value in a char
if (key!=NO_KEY)
DetectButtons();
if (result==true)
CalculateVolume();
DisplayResult();
void DetectButtons() {
lcd.clear(); //Then clean it
if (key=='*') {
Number=Num1=0;
result=false;
if (key == '0'){
if (Number==0)
Number=0;
Number = (Number*10) + 0; //Pressed twice
if (key == '1'){
if (Number==0)
Number=1;
Number = (Number*10) + 1; //Pressed twice
if (key == '2'){
if (Number==0)
Number=2;
Number = (Number*10) + 2; //Pressed twice
if (key == '3'){
if (Number==0)
Number=3;
Number = (Number*10) + 3; //Pressed twice
if (key == '4'){
if (Number==0)
Number=4;
Number = (Number*10) + 4; //Pressed twice
if (key == '5'){
if (Number==0)
Number=5;
Number = (Number*10) + 5; //Pressed twice
if (key == '6'){
if (Number==0)
Number=6;
Number = (Number*10) + 6; //Pressed twice
if (key == '7'){
if (Number==0)
Number=7;
Number = (Number*10) + 7; //Pressed twice
if (key == '8'){
if (Number==0)
Number=8;
Number = (Number*10) + 8; //Pressed twice
if (key == '9'){
if (Number==0)
Number=9;
Number = (Number*10) + 9; //Pressed twice
if(key=='#'){
flowrate();
while(Number*constant>totalMilliLitres ){
lcd.clear();
if(totalMilliLitres==0){
lcd.print("Turn On Water");
delay(10);
if(totalMilliLitres>0){
lcd.print("Watering...");
lcd.setCursor(0,1);
lcd.print("Gal Out:");
lcd.print(totalMilliLitres);
if(Number*constant<=totalMilliLitres ){
lcd.clear();
lcd.print("Done Watering");
delay(5000);
void CalculateVolume(){
void DisplayResult()
lcd.print(Number);
lcd.setCursor(0, 1);
lcd.print("Gal:");
lcd.print(Number*constant);
void flowrate()
if((millis() - oldTime) > 1000) // Only process counters once per second
detachInterrupt(sensorInterrupt);
flowRate = ((1000.0 / (millis() - oldTime)) * pulseCount) / calibrationFactor;
oldTime = millis();
flowMilliLitres = (flowRate / 60) * 1000;
totalMilliLitres += flowMilliLitres;
unsigned int frac;
// Print the flow rate for this second in litres / minute
Serial.print("Flow rate: ");
Serial.print(int(flowRate)); // Print the integer part of the variable
Serial.print("."); // Print the decimal point
// Determine the fractional part. The 10 multiplier gives us 1 decimal place.
frac = (flowRate - int(flowRate)) * 10;
Serial.print(frac, DEC) ; // Print the fractional part of the variable
Serial.print("L/min");
// Print the number of litres flowed in this second
Serial.print(" Current Liquid Flowing: "); // Output separator
Serial.print(flowMilliLitres);
Serial.print("mL/Sec");
// Print the cumulative total of litres flowed since starting
Serial.print(" Output Liquid Quantity: "); // Output separator
Serial.print(totalMilliLitres);
Serial.println("mL");
// Reset the pulse counter so we can start incrementing again
pulseCount = 0;
// Enable the interrupt again now that we've finished sending output
