The urgency of solving this issue, is due to the closing deadline for my project.
Just to give a little background information on my project;
Current components:
- Arduino Uno
- USB Host ADK shield
https://www.amazon.co.uk/gp/product/B00GHD2ZIE/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 - Aibecy Embedded 1D barcode Scanner Reader Module CCD
https://www.amazon.co.uk/gp/product/B07549DWPX/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1 - 20x4 LCD Display module shield
https://www.amazon.co.uk/gp/product/B01GPUMP9C/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 - Micro SD card Reader Module
https://www.amazon.co.uk/gp/product/B06XHJTGGC/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 - Samsung 32gb Micro SD Card
https://www.amazon.co.uk/gp/product/B06XFSZGCC/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Aim of the project:
- To produce a device (using arduino only) that is able to read the barcode of items and lookup further information on that item (looking at a txt/csv file that is stored locally, ideally on an SD card), that is then displayed on an LCD screen. (Overall this device replicates the functionality of barcode scanners in supermarkets that display certain information regarding that item, onto a screen)
Current progress:
Barcode scanner connected correctly and working via a USB host shield (code used is working and is able to display the barcode on a 20x4 I2C LCD screen)
SD card adapter is functioning (able to see that the SD card is connected correctly and works as I was able to read and write to a file saved on the microSD)
LCD works perfectly (able to display barcode/SD/random information)
Problems & required help:
- I am trying to implement the seaparately working components (mainly the Barcode scanner and SD card reader) but have come across an exhausting issue.
The issue that persists is that the arduino continuously restarts every time the file on the SD card is accessed. Funnily enough, when I unplug the barcode scanner, the arduino no longer resets and is able to access the SD. But once plugged back in, the error continuous. Same thing goes for unpluggin the SD adapter and leaving the USB plugged in. Seems to have an issue when both are plugged in at the same time.
(SD focus: The SD is currently being used to match the barcode ID scanned to existing information on a txt file, that then displays information taken from the txt file that is in relation to the matched barcode)
Current Connections:
I am using a breadboard to share the voltage of 5v, between the LCD and microSD card reader.
LCD:
GND -> positive pin (on breadboard)
VCC -> 5v (negative pin on breadboard)
SDA -> A4
SCL -> A5
SD reader:
CS -> 4
MISO -> 12
MOSI -> 11
SCK -> 13
Using a USB host shield for the barcode scanner, so the pin setup is default to a shield host.
Here is the code I have implemented:
//SD SETUP
#include <SD.h>
#include <SPI.h>
int CS_PIN = 4;
File file;
#include <hid.h>
#include <hiduniversal.h>
#include <avr/pgmspace.h>
#include <Usb.h>
#include <usbhub.h>
#include <hidboot.h>
#define DISPLAY_WIDTH 20
LiquidCrystal_I2C lcd(0x27,2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
USB Usb;
USBHub Hub(&Usb);
HIDUniversal Hid(&Usb);
String barcode = "";
char barcodeChar;
bool scanning = false;
int count = 0;
int count2 = 0;
HIDBoot<HID_PROTOCOL_KEYBOARD> Keyboard(&Usb);
class KbdRptParser : public KeyboardReportParser
void PrintKey(uint8_t mod, uint8_t key);
protected:
virtual void OnKeyDown (uint8_t mod, uint8_t key);
virtual void OnKeyPressed(uint8_t key);
public:
void collectBarcode();
void KbdRptParser::OnKeyDown(uint8_t mod, uint8_t key)
uint8_t c = OemToAscii(mod, key);
if (c)
OnKeyPressed(c);
/* what to do when symbol arrives */
void KbdRptParser::OnKeyPressed(uint8_t key)
static uint32_t next_time = 0; //watchdog
static uint8_t current_cursor = 0; //tracks current cursor position
lcd.print((char)key); // displays barcode
barcodeChar = ((char)key); // saves barcode char
barcode = barcode + barcodeChar; // adds barcode char to a string that holds the full barcode ID
scanning = true;
count++;
KbdRptParser Prs;
Serial.begin( 9600 );
Serial.println("Start");
// USB SETUP
initializeScanner();
// SD SETUP
initializeSD();
Usb.Task();
if(count > 7 && scanning == false && count < 14)
Serial.println(barcode);
openFile();
Serial.println(readLine(barcode));
count = 0;
barcode = "";
scanning = false;
void initializeScanner()
if (Usb.Init() == -1) {
Serial.println("OSC did not start.");
Serial.println("Scanner ready");
delay( 200 );
Hid.SetReportParser(0, (HIDReportParser*)&Prs);
lcd.begin(DISPLAY_WIDTH, 4);
lcd.clear();
lcd.noAutoscroll();
lcd.print("Ready");
delay( 200 );
void initializeSD()
// Serial.println("Initializing SD card...");
//pinMode(CS_PIN, OUTPUT);
if (SD.begin(CS_PIN))
Serial.println("SD card ready");
} else
Serial.println("SD card failed");
return;
void openFile()
file = SD.open("Database.txt");
if (file)
Serial.println("File opened!");
} else
Serial.println("Error opening file...");
String readLine(String barcode)
// file = SD.open("Database.txt");
if (file)
//String barcode= "180900038";
String received = "";
String temp = "";
char ch;
bool temptest = false;
Serial.println(F("Reading File"));
while (file.available()) {
ch = file.read();
if (ch == ',') { // Is the tag starting? / as result this is the tag ending
received = "";
} else if(ch == '\n') { // Is the tag ending? / as the result this is the tag start
received = ""; // Empty the string, we don't need br
} else { // Everything's OK, append to the string
received += ch;
if(received == barcode || temptest == true)
temp += ch;
temptest = true;
if (temptest == true && ch == ',')
temp = "";
if(temptest == true && ch == '\n')
return String(temp); //returns the barcode ID
temptest = false;
temp = "";
file.close();
//Serial.println("End of file ");
lcd.setCursor(0, 1);
lcd.print("End of file ");
Serial.println("error opening datalog.txt");
Serial.println("End of read function ");
The result presented in the Serial monitor is below:
Thank you in advance for any help given. My current thought, is that it might be a power or memory issue (my current global variables are using 88% of the dynamic memory) but I am unsure.
