Hi, i'm using a nokia 5110 LCD with arduino uno. it was working fine for quite a while, and then suddenly, it stopped displaying. there's only the blue background. it does not write anything on the LCD.
If you haven't changed the code, your problem is mechanical.
These displays are factory surplus and some may have a short life.
If you squeeze, fiddle, or jiggle, it might work - for a while.
It could be slack installation on your part, and a better job at that might fix the display permanently. If you have been running it off 5v it may have died, but I have heard of users getting away with that.
The background light has nothing to do with the display.
