Urgent Help Reverse Geocache.
So I'm trying to propose to my girlfriend using a Reverse Geocache box (Sunday is the proposal) - using the materials and notes from here:
After putting the unit together (using an Ardunio Uno) - I plugged it in and uploaded code.
When the device is plugged in - it responds - the LCD lights up, the button lights up, and the servo has moved.
However - when on battery power - absolutely nothing. A small light on the chip board lights up when I click the button and that's it. Red wire is on the + as instructed and the little light turning on suggest there is power? So I have no idea why nothing else is responding.
All help would be greatly appreciated.
Mrmadsci:
How?
You have given us neither your code nor your wiring diagram. Or even the type of battery you are using.
And please use the code button </> so your code looks like this and is easy to copy to a text editor
…R
#include <TinyGPS.h>
#include <PWMServo.h>
reverse_geocache_sample_for_rev_2_shield.ino
Sample Arduino Puzzle Box sketch
Written by Mikal Hart
COPYRIGHT (c) 2008-2013 The Sundial Group
All Rights Reserved.
  http://www.sundial.com
This software is licensed under the terms of the Creative
Commons "Attribution Non-Commercial Share Alike" license, version
3.0, which grants the limited right to use or modify it NON-
COMMERCIALLY, so long as appropriate credit is given and
derivative works are licensed under the IDENTICAL TERMS.  For
license details see
  http://creativecommons.org/licenses/by-nc-sa/3.0/
This source code is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
This sketch illustrates how one might implement a basic puzzle box
that incorporates rudimentary aspects of the technology in the
Reverse Geocache(tm) puzzle and the Sundial Quest Box(tm).
"Reverse Geocache" and "Quest Box" are trademarks of The Sundial Group.
Certain technologies used here are Patent Pending.
For supporting libraries (PWMServo, TinyGPS) see
  http://arduiniana.org
This code is available at
#include <SoftwareSerial.h>
#include <EEPROM.h>
#include <LiquidCrystal.h>
 Note: This code is designed to work only with Reverse Geocache(tm)
 shields rev 2.03 or greater made by The Sundial Group.
 The following 5 values should be adjusted according to your situation.
 The easiest way to get a latitude and longitude is to right-click in
 Google Maps and select "What's here?".
 You might also wish to alter the messages that are printed in the code body.
static const int   SERVO_CLOSED_ANGLE = 90;    // degrees (0-180)
static const int   SERVO_OPEN_ANGLE = 165;     // degrees (0-180)
static const float DEST_LATITUDE = 43.498538;  // degrees (-90 to 90)
static const float DEST_LONGITUDE = -79.707631; // degrees (-180 to 180)
static const int   RADIUS = 2000;              // meters
static const int   LCD_CONTRAST = 20;          // (0-255)
/* Fixed values should not need changing */
static const int DEF_ATTEMPT_MAX = 50;
static const int EEPROM_OFFSET = 100;
/* Pin assignments */
static const int GPS_RX_PIN = 4, GPS_TX_PIN = 3; // GPS
static const int LCD_ENABLE_PIN = 7, LCD_RS_PIN = 5, LCD_RW_PIN = 8; // LCD
static const int LCD_DB4_PIN = 14, LCD_DB5_PIN = 15, LCD_DB6_PIN = 16, LCD_DB7_PIN = 17;
static const int LCD_CONTRAST_PIN = 6;
static const int POLOLU_SWITCH_PIN = 12; // Pololu switch control
static const int SERVO_CONTROL_PIN = 9; // Servo control
static const int LED_PIN = 2; // The button LED
static const int PIEZO_PIN = 11; // Piezo buzzer outlet
/* The basic objects needed */
static SoftwareSerial ss(GPS_RX_PIN, GPS_TX_PIN);
static LiquidCrystal lcd(LCD_RS_PIN, LCD_RW_PIN, LCD_ENABLE_PIN, LCD_DB4_PIN, LCD_DB5_PIN, LCD_DB6_PIN, LCD_DB7_PIN);
static TinyGPS tinyGps;
static int attemptCounter;
static PWMServo servo;
/* The Arduino setup() function */
  /* Uncomment this code if you want to reset the attempt counter. */
    EEPROM.write(EEPROM_OFFSET, 0);
    exit(0);
  /* First, make sure Pololu switch pin is OUTPUT and LOW */
  pinMode(POLOLU_SWITCH_PIN, OUTPUT);
  digitalWrite(POLOLU_SWITCH_PIN, LOW);
  /* attach servo motor */
  servo.attach(SERVO_CONTROL_PIN);
  /* establish a debug session with a host computer */
  /* establish communications with the GPS module */
  ss.begin(4800);
  /* set the LCD contrast value */
  pinMode(LCD_CONTRAST_PIN, OUTPUT);
  analogWrite(LCD_CONTRAST_PIN, LCD_CONTRAST);
  /* establish communication with 8x2 LCD */
  lcd.begin(8, 2); // this for an 8x2 LCD -- adjust as needed
  /* turn on the LED in the button */
  pinMode(LED_PIN, OUTPUT);
  digitalWrite(LED_PIN, HIGH);
  /* make sure motorized latch is closed */
  servo.write(SERVO_CLOSED_ANGLE);
  /* read the attempt counter from the EEPROM */
  attemptCounter = EEPROM.read(EEPROM_OFFSET);
  if (attemptCounter == 0xFF) // brand new EEPROM?
    attemptCounter = 0;
  /* increment it with each run */
  ++attemptCounter;
  /* Copyright notice */
  Msg(lcd, "(C) 2013", "Sundial", 1500);
  /* Greeting */
  Msg(lcd, "Welcome", "to your", 2000);
  Msg(lcd, "puzzle", "box!", 2000);
  /* Game over? */
  if (attemptCounter >= DEF_ATTEMPT_MAX)
    Msg(lcd, "Sorry!", "No more", 2000);
    Msg(lcd, "attempts", "allowed!", 2000);
    PowerOff();
  /* Print out the attempt counter */
  Msg(lcd, "This is", "attempt", 2000);
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print(attemptCounter);
  lcd.print(" of ");
  lcd.print(DEF_ATTEMPT_MAX);
  delay(2000);
  /* Save the new attempt counter */
  EEPROM.write(EEPROM_OFFSET, attemptCounter);
  Msg(lcd, "Seeking", "Signal..", 0);
/* The Arduino loop() function */
  /* Has a valid NMEA sentence been parsed? */
  if (ss.available() && tinyGps.encode(ss.read()))
    float lat, lon;
    unsigned long fixAge;
    /* Have we established our location? */
    tinyGps.f_get_position(&lat, &lon, &fixAge);
    if (fixAge != TinyGPS::GPS_INVALID_AGE)
      /* We got a fix! */
      Chirp(true);
      /* Calculate the distance to the destination */
      float distance_meters = TinyGPS::distance_between(lat, lon, DEST_LATITUDE, DEST_LONGITUDE);
      /* Are we close?? */
      if (distance_meters <= RADIUS)
        Msg(lcd, "Access", "granted!", 2000);
        servo.write(SERVO_OPEN_ANGLE);
      /* Nope.  Print the distance. */
        lcd.clear();
        lcd.print("Distance");
        lcd.setCursor(0, 1);
        if (distance_meters < 1000)
          lcd.print((int)distance_meters);
          lcd.print(" m.");
          lcd.print((int)(distance_meters / 1000));
          lcd.print(" km.");
        delay(4000);
        Msg(lcd, "Access", "Denied!", 2000);
      PowerOff();
  /* Turn off after 5 minutes */
  if (millis() >= 300000)
    PowerOff();
/* Called to shut off the system using the Pololu switch */
void PowerOff()
  Chirp(false);
  Msg(lcd, "Powering", "Off!", 2000);
  lcd.clear();
  /* Bring Pololu switch control pin HIGH to turn off */
  digitalWrite(POLOLU_SWITCH_PIN, HIGH);
  /* This is the back door.  If we get here, then the battery power */
  /* is being bypassed by the USB port.  We'll wait a couple of */
  /* minutes and then grant access. */
  delay(120000);
  servo.write(SERVO_OPEN_ANGLE); // and open the box
  /* Reset the attempt counter */
  /* Leave the latch open for 10 seconds */
  delay(10000);
  /* And then seal it back up */
  /* Exit the program for real */
  exit(1);
/* A helper function to display messages of a specified duration */
void Msg(LiquidCrystal &lcd, const char *top, const char *bottom, unsigned long del)
  lcd.clear();
  lcd.print(top);
  lcd.print(bottom);
  delay(del);
static void Chirp(bool up)
  static const int A = 1760;
  static const int E = 2637;
  static const int CS = 2218;
  static const int duration = 100;
  int tone1 = up ? A : E;
  int tone2 = up ? E : A;
  ss.end();
  tone(PIEZO_PIN, tone1, duration);
  delay(duration);
  noTone(PIEZO_PIN);
  tone(PIEZO_PIN, tone2, duration);
  delay(duration);
  noTone(PIEZO_PIN);
  ss.begin(4800);
Sorry - there’s the code. I followed the instructions on the site so I don’t really have a diagram or anything. I’m entirely new to this DIY chip tech stuff so forgive me.
Here are some pictures:
http://puu.sh/nHMrS/e75107a2b3.jpg
http://puu.sh/nHMtN/9628170c31.jpg
http://puu.sh/nHMwq/7900429b6b.jpg
You are going to need more battery capacity than that, its only 2 x AA = 3V, check the spec of your servo, the UNO will need at least 5V to run as well.
Use a DMM and measure the battery voltage as you turn it ON and as you run it.
How much life do you need out of the battery?
Tom... :slight_smile:
Images from Reply #2. See Image Guide
…R
TomGeorge:
So this is the servo I used:
http://hitecrcd.com/products/servos/micro-and-mini-servos/analog-micro-and-mini-servos/hs-55-economy-feather-servo/product
Occurring to the above, If I've read it correctly - it requires 6 volts + the arduino's 5 + the LCD's Driver Voltage: 5 VDC.
What size battery pack do you recommend - and i also can't thank you enough for your reply - honestly I'm in such a pickle!
An Uno and a servo with little or no load on it should work from 3xAA cells (4.5v) if you connect the battery directly to the Uno 5v pin.
I have used this for demoing stuff - with a Mega, a Leonardo and 2 small servos running of the same 3 cells.
...R
