[URGENT] How to Control Servo using Switch Button
Hi, I have padlock project. I'm using Arduino Nano and Servo. The padlock will be lock if the servo angle is 90 and will be unlock if the servo angle is 60.
So, I'm thinking about getting back the servo from 60 to 90 using a switch button. But, I don't know what's wrong with my code. Here's my code :
    #include <Servo.h>
    Servo slock;  // create servo object to control a servo
    int pos = 90;    // variable to store the input servo position
    int buttonLock = 2; // lock button location
    int buttonState = 0; // variable for reading lock button status
     Serial.begin(9600);  // initialize serial:
     slock.attach(9);  // attaches the servo on pin 9 to the servo object
     pinMode(buttonLock, INPUT); // set lock button as input
      buttonState = digitalRead(buttonLock);
      if (Serial.available() > 0)   // if there's any serial available, read it:
        pos = Serial.parseInt();  // get the input variable for position
        if ((pos > 59) && (pos < 91)) //ignore anything less than 90 or greater than 60
            Serial.print(pos);  //print the value to the serial monitor
            slock.write(pos);  // tell servo to go to position in variable 'pos'
          delay(15);  // waits 15ms for the servo to reach the position
         if (buttonState == HIGH) // button pushed
            slock.write(90); // lock the servo
        delay(15);
When I upload the code above, whenever I send serial 60 from the serial monitor, the servo will bounce back to 90. Any ideas about where I do wrong with the code? Thank you!
I have tried your code. When I type 60 it goes to 60 when I type 90 it goes to 90.
when I press the button it goes to 90
How do you connect the button?
May I suggest you use pinMode(buttonLock, INPUT_PULLUP);
and change your code to
if (buttonState == LOW) // button pushed
just hook up a button to this pin to the ground (no resistors needed) and retry it
Good luck!
Thank you very much for the reply. I think I connect the button in wrong way. How to connect the button properly?
siutoejai:
Good luck!
Good work here from Mr. Gammon:
LarryD:
Gammon Forum : Electronics : Microprocessors : Switches tutorial
Thank you very much for the help.
