URGENT! Need help with Key Pad
Hello,
We need help with an issue with our key pad and LCD display. The code is attached below, our problem is that the 1, 2, 3 keys in the key pad doesn’t get registered to display when pressed.
#include <LiquidCrystal.h> //include LCD library (standard library)
#include <Keypad.h> //include keypad library - first you must install library (library link in the video description)
const byte rows = 4; //number of the keypad's rows and columns
const byte cols = 4;
char keyMap [rows] [cols] = { //define the cymbols on the buttons of the keypad
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
byte rowPins [rows] = {1, 2, 3, 4}; //pins of the keypad
byte colPins [cols] = {5, 6, 7, 8};
long Num1,Number;
char key,action;
boolean result = false;
float constant = 0.623;
Keypad myKeypad = Keypad( makeKeymap(keyMap), rowPins, colPins, rows, cols);
LiquidCrystal lcd(A0, A1, A2, A3, A4, A5);
lcd.begin(16, 2);
lcd.setCursor(3, 0);
lcd.print("WaterRight");
delay(2000);
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Enter Area:");
key = myKeypad.getKey(); //storing pressed key value in a char
if (key!=NO_KEY)
DetectButtons();
if (result==true)
CalculateVolume();
DisplayResult();
void DetectButtons() {
  lcd.clear(); //Then clean it
  if (key=='*') {
    Serial.println ("Clear");
    Number=Num1=0;
    result=false;
  if (key == '0'){
    Serial.println ("Button 0");
  if (Number==0)
    Number=0;
    Number = (Number*10) + 0; //Pressed twice
  if (key == '1'){
    Serial.println ("Button 1");
  if (Number==0)
    Number=1;
    Number = (Number*10) + 1; //Pressed twice
  if (key == '2'){
    Serial.println ("Button 2");
  if (Number==0)
    Number=2;
    Number = (Number*10) + 2; //Pressed twice
  if (key == '3'){
    Serial.println ("Button 3");
  if (Number==0)
     Number=3;
     Number = (Number*10) + 3; //Pressed twice
  if (key == '4'){
    Serial.println ("Button 4");
  if (Number==0)
    Number=4;
    Number = (Number*10) + 4; //Pressed twice
  if (key == '5'){
    Serial.println ("Button 5");
  if (Number==0)
    Number=5;
    Number = (Number*10) + 5; //Pressed twice
  if (key == '6'){
    Serial.println ("Button 6");
  if (Number==0)
    Number=6;
    Number = (Number*10) + 6; //Pressed twice
  if (key == '7'){
    Serial.println ("Button 7");
  if (Number==0)
    Number=7;
    Number = (Number*10) + 7; //Pressed twice
   if (key == '8')
    Serial.println ("Button 8");
   if (Number==0)
  Number=8;
  Number = (Number*10) + 8; //Pressed twice
  if (key == '9'){
    Serial.println ("Button 9");
  if (Number==0)
    Number=9;
    Number = (Number*10) + 9; //Pressed twice
  if(key=='#'){
    while(true){
    lcd.clear();
    lcd.print("Watering...");
    lcd.noDisplay();
    lcd.display();
void CalculateVolume(){
void DisplayResult()
lcd.print(Number);
lcd.setCursor(0, 1);
lcd.print("Volume:");
lcd.print(Number*constant);
Thank You
To make it easy for people to help you please modify your post and use the code button </> so your code looks like this and is easy to copy to a text editor. See How to use the Forum
Your code is too long for me to study quickly without copying to a text editor.
Also use the AutoFormat tool to indent your code for easier reading,
…R
On UNO and similar Arduinos, pin 1 is used for Serial transmission. Your use of pin 1 for the first row of the keypad will conflict with this and probably explains why you can’t get the 1, 2, 3 keys to work.
Whether or not that is the problem, you should read How to post code properly and then use the </> icon to create
[code]...[/code]
tags around your code so that it is easier to read.
Pete
    if (key == '0'){
    if (Number==0)
      Number=0;
    if (key == '1'){
    if (Number==0)
      Number=1;
    if (key == '2'){
    if (Number==0)
      Number=2;
etc, etc
Do you notice that your code is basically the same for each digit pressed ?
All you need to do is to test that the key pressed is between '0 and '9', subtract '0' from the key value to get an actual number then add it to 10 times the current total.
if (Number==0)
      Number=0;
If the bottle is empty, empty it 8)
No matter what we do the key pad does not display or register the 1, 2, 3 keys while all the other keys like 4, 5, 6 works. Please look over the code and see if something is amiss
long Num1,Number;
char key,action;
lcd.begin(16, 2);
delay(2000);
lcd.clear();
if (key!=NO_KEY)
DetectButtons();
if (result==true)
CalculateVolume();
DisplayResult();
  if (key=='*') {
    Number=Num1=0;
    result=false;
  if (key == '0'){
  if (Number==0)
    Number=0;
  if (key == '1'){
  if (Number==0)
    Number=1;
  if (key == '2'){
  if (Number==0)
    Number=2;
  if (key == '3'){
  if (Number==0)
     Number=3;
  if (key == '4'){
  if (Number==0)
    Number=4;
  if (key == '5'){
  if (Number==0)
    Number=5;
  if (key == '6'){
  if (Number==0)
    Number=6;
  if (key == '7'){
  if (Number==0)
    Number=7;
   if (key == '8')
   if (Number==0)
  Number=8;
  if (key == '9'){
  if (Number==0)
    Number=9;
  if(key=='#'){
    while(true){
    lcd.clear();
    lcd.noDisplay();
    lcd.display();
lcd.print(Number);
Thank you
digital pin 1 is used for serial output, you can't share it with the button pad and expect both serial and the button pad to work
Why did you start a new thread? One answer in your other thread gave the same answer about pin 1.
Threads merged.
