Urgent problem on Qtr-8rc pid line following
#include <PololuQTRSensors.h>
// motor driver pin
#define out_STBY 6
#define out_B_PWM 9
#define out_A_PWM 3
#define out_A_IN2 4
#define out_A_IN1 5
#define out_B_IN1 7
#define out_B_IN2 8
#define motor_A 0
#define motor_B 1
#define NUM_SENSORS 5 // number of sensors used - numero di sensori usati
#define TIMEOUT 2500 // waits for 2500 us for sensor outputs to go low - aspetta 2500 us prima di mandare low i sensori
//define QTR pololu sensor
PololuQTRSensorsRC qtrrc((unsigned char[]) {2, 10, 11, 12, 13}
, NUM_SENSORS, TIMEOUT, 255);
unsigned int sensors[NUM_SENSORS];
// define motor drive output pin - definisci i pin di output del motore
pinMode(out_STBY,OUTPUT);
pinMode(out_A_PWM,OUTPUT);
pinMode(out_A_IN1,OUTPUT);
pinMode(out_A_IN2,OUTPUT);
pinMode(out_B_PWM,OUTPUT);
pinMode(out_B_IN1,OUTPUT);
pinMode(out_B_IN2,OUTPUT);
motor_standby(false);// motor stand-by off and stop - togli i motori dallo stand-by e fermali
stopMotors();
delay(2000);
SensorCalibration(); // sensor calibration - calibra i sensori
delay(2000);
follow_segment(); // follow the black line - segui la linea nera
// PID parameters
int Kp=120;
int Ki=100;
int Kd=100;
void follow_segment()
int last_proportional = 0;
long integral=0;
int primo=0;
int posizione = qtrrc.readLine(sensors); // read the IR sensors - leggi i sensori IR
long int proportional = posizione;
int P = proportional * Kp/1000; // Proportional parameter
long int derivative = proportional - last_proportional; //Derivative parameter
if (primo==0) // firt cycle set derivative to zero - al primo giro imposta il derivativo a zero
primo=1;
derivative=0;
int D=derivativeKd/1000;
integral += proportional;
int I=integral
Ki/1000; //integral parameter
// Remember the last position - ricorda l'ultima posizione
last_proportional = proportional;
int PID =P + I + D; //calculate the PID
// print some values on the serial port - scrivi qualche valore sulla seriale
unsigned char zz;
for (zz = 0; zz < NUM_SENSORS; zz++)
Serial.print(sensors[zz]);
Serial.print(' ');
Serial.print(" position: ");
Serial.print(posizione);
Serial.print(" P:");
Serial.print(P);
Serial.print(" I:");
Serial.print(I);
Serial.print(" D:");
Serial.print(D);
Serial.print(" PID:");
Serial.print(PID);
// set the values for the motors based on the PID gain - setta i valori del motore basati sul PID
const int maximum = 40; // the maximum speed
if (PID > 0){
if (PID > maximum) PID=maximum;
motor_speed2(motor_B,maximum);
motor_speed2(motor_A,maximum-PID);
Serial.print(" Motore_B:"); Serial.print(maximum);
Serial.print(" Motore_A:"); Serial.print(maximum-PID);
else {
if (PID < -maximum) PID=-maximum;
motor_speed2(motor_B,maximum+PID);
motor_speed2(motor_A,maximum);
Serial.print(" Motore_B:"); Serial.print(maximum+PID);
Serial.print(" Motore_A:"); Serial.print(maximum);
Serial.println("");
// ------------------ stop the robot - ferma il robottino -----------------------
void stopMotors(){
motor_brake(motor_A);
motor_brake(motor_B);
// ------------------ Motor driver mgmt routines - routine per gestire i motori -----------------------
void motor_speed2(boolean motor, char speed) { //speed from 0 to 100
if (motor == motor_A)
speed = -speed;
byte PWMvalue=0;
PWMvalue = map(abs(speed),0,100,50,255); //anything below 50 is very weak
if (speed > 0)
motor_speed(motor,0,PWMvalue);
else if (speed < 0)
motor_speed(motor,1,PWMvalue);
else {
motor_coast(motor);
void motor_speed(boolean motor, boolean direction, byte speed) { //speed from 0 to 255
if (motor == motor_A) {
if (direction == 0) {
digitalWrite(out_A_IN1,HIGH);
digitalWrite(out_A_IN2,LOW);
digitalWrite(out_A_IN1,LOW);
digitalWrite(out_A_IN2,HIGH);
analogWrite(out_A_PWM,speed);
digitalWrite(out_B_IN1,HIGH);
digitalWrite(out_B_IN2,LOW);
digitalWrite(out_B_IN1,LOW);
digitalWrite(out_B_IN2,HIGH);
analogWrite(out_B_PWM,speed);
// stand-by motor
void motor_standby(boolean state) { //low power mode
if (state == true)
digitalWrite(out_STBY,LOW);
digitalWrite(out_STBY,HIGH);
// stop the motors
void motor_brake(boolean motor) {
// motors coast - fai girare i motori in folle
void motor_coast(boolean motor) {
digitalWrite(out_A_PWM,HIGH);
digitalWrite(out_B_PWM,HIGH);
// IR sensor calibration
void SensorCalibration() {
int counter, i;
for (counter=0; counter<40; counter++)
if (counter < 10 || counter >= 30) {
motor_speed2(motor_A,10);
motor_speed2(motor_B,-10);
else {
motor_speed2(motor_A,-10);
motor_speed2(motor_B,10);
qtrrc.calibrate();
// Since our counter runs to 80, the total delay will be
// 8020 = 1600 ms.
delay(20);
// print the calibration minimum values measured when emitters were on
for (i = 0; i < NUM_SENSORS; i++)
Serial.print(qtrrc.calibratedMinimumOn
  • Serial.print(' ');*
  • Serial.println();*
  • // print the calibration maximum values measured when emitters were on*
  • for (i = 0; i < NUM_SENSORS; i++)*
    _ Serial.print(qtrrc.calibratedMaximumOn*);_
    _
    Serial.print(' ');_
    _
    }_
    _
    Serial.println();_
    _
    Serial.println();_
    _
    stopMotors();_
    _
    delay(2000);_
    _
    }*_
    This is my code and it doesn't follow black line It is urgent because it is my term project I hink it doesnt work because of the getting sensor output always motore b:40 and motore a:0 but when the sensors are seeing all white then both of them speed is 40.
    Pls help me i cant solve the th problem
You have far too much going on in this sketch. Delete all the code that diddles with the motors. That code is useless until you KNOW that you are getting good data from all 5 sensors.
Delete all the code that deals with PID. Likewise, that code is useless until you KNOW that you are getting good data from all 5 sensors.
Write some code that simply prints out the values read from the 5 sensors as they move over various colored surfaces. Until that code works, you are wasting your time writing more code.
