*URGENT* proximity sensor code not working
I need urgent help with this code.
I am connecting a proximity sensor that plays sound when activated for one minute. I keep getting an error but am unsure why.
Is anyone able to assist? I have attached my code bellow.
Thank you!
#include <pcmConfig.h>
#include <pcmRF.h>
#include <TMRpcm.h>
#include <Event.h>
#include <Timer.h>
#include <Event.h>
#include <Timer.h>
#include "TMRpcm.h"
#include "SD.h"
#define SD_ChipSelectPin 4
#include "TMRpcm.h"
#include "SPI.h"
TMRpcm tmrpcm;
#define ds_pin A0 // Pin to which the distance sensor is connected
#define ds_pin_1 A1 // Pin to which the distance sensor is connected
#define ds_pin_2 A2 // Pin to which the distance sensor is connected
#define ds_pin_3 A3 // Pin to which the distance sensor is connected
Timer t;
int red_pin = 6;
int green_pin = 7;
int ds_value=0; // Integer to hold the sensor’s reading
int ds_value_1=0; // Integer to hold the sensor’s reading
int ds_value_2=0; // Integer to hold the sensor’s reading
int ds_value_3=0; // Integer to hold the sensor’s reading
int status_red;
  tmrpcm.speakerPin = 9;
  if (!SD.begin(SD_ChipSelectPin)) {
Serial.println("SD fail");
return;
 tmrpcm.setVolume(10);
tmrpcm.play("rain.wav");
  pinMode(red_pin, OUTPUT);
  pinMode(green_pin, OUTPUT);
  t.oscillate(red_pin, 1 * 1000, HIGH); // 10 minutes
  t.oscillate(green_pin, 1 * 1000, LOW);// 10 minutes
  t.update();
  ds_value = analogRead (ds_pin);  // Reads the distance sensor
  ds_value_1 = analogRead (ds_pin_1);  // Reads the distance sensor
  ds_value_2 = analogRead (ds_pin_2);  // Reads the distance sensor
  ds_value_3 = analogRead (ds_pin_3);  // Reads the distance sensor
  status_red=digitalRead(red_pin);if(ds_value<3000 && ds_value_1<300 status_red==0)
    //play light music
   tmrpcm.play("music.wav");
  else if(ds_value_2<300 && ds_value_3<300 status_red==1)
    //play thunder
    tmrpcm.play("thunder.wav");
  tmrpcm.stopPlayback()
  delay (200);                  // Delay of 200ms
at the }
else if(ds_value_2<300 && ds_value_3<300 status_red==1) part it states expected ‘)’ before ‘status_red’
Arduino_task2.ino (1.71 KB)
When I do that, another error comes up.
at
its the same error that pops up, do I need to get rid of the () as well??
Thank you
You need to fill the space. Try &&
We have NO idea what "that" is you did.
You KNOW how to use && in an if statement. Why do you not use && between ALL the clauses?
That worked, now there’s another error
else if ds_value_2<300 && ds_value_3<300 status_red==1
now this one has the same error, and i tried the && that also didn’t work
Sorry, I got the code from a friend because I don’t know how to code
thank you
and PaulS… I DONT KNOW HOW TO CODE THAT’S WHY I AM ASKING…
And now you're missing both ( and ), and &&
I added the () but it comes up as expected ) before status red
Thank you for helping AWOL
If you changed your code, you need to post it again. Are you still missing the && between the last two clauses?
stevenskintzis:
And if you’d said that earlier instead of saying " I have attached my code" you might have got some different answers.
If you can post the complete latest version and then say exactly what problems you have with THAT version it will be a lot easier to help.
Steve
Do you believe that writing “URGENT” somehow motivates others to want to help you more? It has the opposite effect on me.
I'm sensing "late assignment"
I think I have got the code working now. Thank you everyone.
