URGENT: Robot Sumo code not working
Hi, guys! I have been working on my Robot Sumo project for months and it still doesn't work and i can't tell why is that. My project is due tomorrow so i'm in need of urgent help.
I use an Atmega328p, programmed with Atmel Studio 7.0, as a processing unit and two tcr5000 line sensors, one on the front of the robot and one on the back. To control the motors I use an L293D. When I test the code the robot even moves, but when the tcr5000 sensors detect the black colour it does not invert the direction of march as it was supposed to. I have already checked and the voltage values that come out of the sensors are correct, voltages very close to 5V for the white colour and reduced voltages for the black colour, so the problem must be with the code.
The code I am using is the following:
#define F_CPU 16000000
#include <stdint.h>
#include <stdlib.h>
#include <string.h>
#include <stdio.h>
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
uint8_t flagdadosrecebidos = 0;
uint8_t flagligado = 0;
uint8_t flagfe = 0;
uint8_t flagfd = 0;
uint8_t flagte = 0;
uint8_t flagtd = 0;
uint8_t flagatuarmotores = 0;
uint8_t i;
uint8_t ligado = 0;
int fe = 0;
int fd = 0;
int te = 0;
int td = 0;
int feito = 0;
unsigned int MaxSVal = 716;
void init(void)
	ADMUX  |= (1 << REFS0);
	ADCSRA |= (1 << ADEN)|(1 << ADPS2)|(1 << ADPS1)|(1<<ADPS0);
	DDRD |= (1<<PORTD3)|(1<<PORTD5)|(1<<PORTD6)|(1<<PORTD7);
	DDRB |= (1<<PORTB0)|(1<<PORTB3)|(1<<PORTB4)|(1<<PORTB5);
	TCCR2A |=(1 << COM2A1) | (1 << COM2B1) | (1 << WGM21) | (1 << WGM20);
	TCCR2B |= (1<<CS20);
	sei();
void ler_sl(void)
	ADMUX = 0B01000000;
	switch (ADMUX){ // vamos ler os valores recebidos nos pins analogicos para ver se estamos no branco ou no preto
		case(0B01000000): // ler o primeiro sensor que se vai encontrar em frente na esquerda
		ADCSRA |= (1 << ADSC);
		while ((ADCSRA & (1<<ADSC)) !=0)
			if (ADCH < MaxSVal) // se estiver a ver preto ADCH > 175 a flag do sensor ativa e posteriormente alterara o comportamento das rodas
				fe = 1;
				}else{
				fe = 0;
		ADMUX = 0B01000010;
		case(0B01000010): // ler o terceito sensor, traseira esquerda
			if (ADCH < MaxSVal)
				td = 1;
				}else{
				td = 0;
		ADMUX = 0B01000000;
void atuarmotores(void){
	if ((fe == 1))
		PORTD = (1<<PORTD7);
		PORTB = (1<<PORTB4);
		OCR2A = 255;
		OCR2B = 255;
	if ((td == 1))
		PORTD = (1<<PORTD5);
		PORTB = (1<<PORTB5);
		OCR2A = 255;
		OCR2B = 255;
int main(void)
	init();
	OCR2A = 255;
	OCR2B = 255;
	while (1)
		ler_sl();
		atuarmotores();
I appreciate all the help possible, it is a very important project.
Thank you!
Welcome to the forum
When you call the ler_sl() function the value of ADMUX is set unconditionally to 0B01000000 but in that function you have a switch/case based on the value of ADMUX
What do you expect the value to be except the value that you just set it to ?
Thank you
How do you suggest I read both inputs? I am a beginner in this kind of programming so I believe that the approach is not the right one.
Personally I would start by using the standard setup() and loop() structure of an Arduino sketch in the Arduino IDE and then use the standard Arduino digitalRead() function to read the value of the sensors
Did you deliberately choose to program this project in a different way ?
I can't program using the Arduino IDE, I have to use Atmel Studio. It is mandatory to make the project in Atmel Studio, unfortunately.
What amazes me most is that you have been
and have only discovered the day before the project was due to be complete that you cannot read the sensors
Given that, please explain how you think that the ler_sl() should work when the first thing that it does is to set value of ADMUX to the same value every time that it is called
This is a genuine question on my part as I know nothing of the use/abuse of the ADMUX register
I already knew that the sensors were not working but I tried to solve alone and with help from colleagues, I just remembered to try forums today.
In relation to ADMUX I was trying to do so at the suggestion of a colleague, I thought that as I changed the value of ADMUX just before the second case would be enough for him to make the switch between analogue ports
