Urgent! Trying to use usbtiny ISP to flash a hex file onto the 16u2 chip of mega
Hi folks,
I am currently working on a MIDI controller prototype using Hiduino.
(GitHub - ddiakopoulos/hiduino: Native USB-MIDI on the Arduino).
I successfully managed to flash this firmware onto the 16u2 about a year ago (With great effort)
and now I have to do it again. The problem is I keep getting the following error:
My command is
avrdude -p m16u2 -P usb -c usbtiny -U flash:w:usbserial_mega_16u2.hex -v
and the response I get is:
avrdude: Version 6.0.1, compiled on Sep 18 2013 at 08:20:41
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Users\Jamie\Desktop\avrdude.conf"
Using Port : usb
Using Programmer : usbtiny
avrdude: usbdev_open(): Found USBtinyISP, bus:device: bus-0:\.\libusb0-0001--0x1781-0x0c9f
AVR Part : ATmega16U2
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC6
RESET disposition : possible i/o
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 512 4 128 9000 9000 0x00 0x00
flash 65 6 128 0 yes 16384 128 128 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : USBtiny
Description : USBtiny simple USB programmer, USBtinyISP - Inexpensive USB AVR Programmer
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
usbtiny does appear to be working but it just wont communicate.
The mega is brand new :confused:
I am at my wits end having been trying to fix this for over 8 hours now
Try this to see if you are hooked up right.
$ avrdude -p m16u2 -P usb -c usbtiny
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9489 (probably m16u2)
avrdude: safemode: Fuses OK (E:F4, H:D9, L:FF)
The ATmega16U2 supports DFU programming over USB. So you can just use Atmel Flip or dfu-programmer to flash the hex file.
Full instructions can be found here.
Pieter
Kprims I did that and got the same result.
In the end I suceeded through the DFU method although when I try to rename the device it still enumerates as arduino_midi.
However the ISP works fine when programming the 2560 in the arduino IDE so I don't know what gives.
gigajoules:
Did you compile the firmware yourself?
Pieter
PieterP:
Pieter
Yes, Even had to install Gnu make for windows and mess with my path variables to do so.
Why is this urgent?
INTP:
Why is this urgent?
Because I am working on a project that I want to get to market.
At the time I was not able to get the firmware on the chip at ALL until I discovered the DFU method, and therefore couldn't proceed with my project
