DaveO
April 2, 2012, 2:18pm
1
I have the following function which sends text to a php script. But the php script only gets the first word of the sentence.
How do I convert the LogTxt to something that the php will receive as a sentence ?
eg : sending : this is a line, of data, 1,2,3
void LogItWebC(char* LogTxt){
if (client.connect(myserver, 80)) {
Serial.println("connected");
client.print("GET http://www.AAA.co.za/serveit.php?data=");
client.print(LogTxt);
client.println(" HTTP/1.1");
client.println("Host: www.AAA.co.za");
client.println();
delay(250);
client.stop();
Serial.println(LogTxt);
Serial.println("disconnected");
Serial.println("==================");
else {
Serial.println("connection failed");
system
April 2, 2012, 2:38pm
2
You need to replace certain characters, like space, with different characters. Space becomes %20. You can look at how php encodes URLs and have the Arduino encode the same characters the same way.
DaveO
April 2, 2012, 2:57pm
3
do you know if there is an available function that can do this without me needing to write code for it ?
system
April 2, 2012, 3:42pm
5
Feeling lazy today, are we?
unsigned char specials[] = " "; /* String containing chars you want encoded */
static unsigned char hex_digit(unsigned char c)
{ return "01234567890ABCDEF"[c & 0x0F];
unsigned char *urlencode(unsigned char *dst,unsigned char *src)
{ unsigned char c,*d = dst;
while (c = *src++)
{ if (strchr(specials,c))
{ *d++ = '%';
*d++ = hex_digit(c >> 4);
*d++ = hex_digit(c);
else *d++ = c;
return dst;
Edit: added declaration of c
DaveO
April 2, 2012, 4:56pm
6
OK. So if I get this right, I add the code sample you kindly supplied below my existing function, and change the specials value to :
unsigned char specials[] = "§_DISCOURSE_HOISTED_CODE_0_§+,/:;=?@ <>#%{}|\^~[]`"; /* String containing chars you want encoded */
and in my function I add :
char URLed = urlencode(LogTxt);
then I get an error on compile :
Invalid conversion from 'char*' to 'unsigned char*'
I have only a basic understanding of why this is happening, but not of how to solve it.
Also, the urlencode function appears to require 2 variables passed to it ( dst and src ). What are they ? I only have 1 char ( LogTxt ) that I want encoded.
system
April 2, 2012, 5:08pm
7
Change all the unsigned chars to signed chars. That is, simply removed the unsigned keyword.
The encoded string will be longer than the original string, so you need to define and supply a place to store the encoded string.
DaveO
April 2, 2012, 5:12pm
8
char specials[] = "§_DISCOURSE_HOISTED_CODE_0_§+,/:;=?@ <>#%{}|~[]`"; ///* String containing chars you want encoded */
static char hex_digit(char c)
char* urlencode(char* dst,char* src)
{ char *d = dst;
while (c = *src++)
{ *d++ = '%';
else *d++ = c;
return dst;
'c' was not declared in this scope
system
April 2, 2012, 5:20pm
9
{ char *d = dst;
char c;
DaveO
April 2, 2012, 5:25pm
10
Many Thanks
Now the (hopefully) last issue is : what should be passed to :
as it looks like it is expecting 2 variables to be passed to it.
system
April 2, 2012, 5:37pm
11
char encodedTxt[120];
urlencode(encodedTxt, LogTxt);
// client.print(LogTxt);
client.print(encodedTxt);
system
April 2, 2012, 5:39pm
12
PaulS first: Yuppers, I should have caught that before posting and you spotted it before I could correct. Thank you.
Dave next: You'll want a buffer to convert into and output from. For sake of discussion, let's call it 'buffer' and make it 80 chars wide:
char buffer[80];
will probably do the job. Now all that's needed is to recode to
client.print(urlencode(buffer,LogTxt));
to output that line in a urlencoded form.
DaveO
April 2, 2012, 5:44pm
13
Many Thanks all. ALMOST there.
now the line :
gives the error : invalid conversion from 'char*' to 'unsigned char*'
Should I just remove all the 'unsigned' keywords ?
system
April 2, 2012, 5:58pm
14
That's what Paul suggested - it'll work. You'll also need to add
#include <string.h>
to your headers to get a prototype for strchr().
DaveO
April 2, 2012, 6:08pm
15
couldn't add :
#include <string.h>
as it doesn't exist in my libraries.
I ran the code without it and working well, except for a few odd characters appearing :
2012-04-02---20:01:32 Setup Completed - System OperationalÝ
2012-04-02---20:01:34 Doors OpenN!
and the = converting to < in this line :
2012-04-02---20:01:33 EEProm < 0 (sms OFF+ Home)0state
I added the following to the variable :
system
April 2, 2012, 6:26pm
16
My bad (trying to carry on too many conversations at once) - I forgot to terminate the output string.
Let's try:
static char hex_digit(c)
char *urlencode(char *dst,char *src)
{ char c,*d = dst;
while (c = *src++)
{ *d++ = '%';
c = hex_digit(c);
*d++ = c;
*d = '\0';
return dst;
It's strange to me that there's no string.h header file, but it'd appear not to have been needed. My ignorance knows no bounds!
Edit: Removed #include and simplified
DaveO
April 2, 2012, 9:25pm
17
Thanks Morris
Working like a dream now !!
Thank You so very much.
Lastly, I just have a question about this function, so that I can hopefully understand it properly :
Is the purpose of this function to return either the character found in the string 01234567890ABCDEF, or if not found, then return the Hex of the 'char c' ?
If so, shouldn't the line 01234567890ABCDEF contain all 26 alpha letters, both upper and lower case ?
system
April 2, 2012, 9:55pm
18
It converts the binary value of the low-order four bits of its argument to a hexadecimal digit character . By convention, the digits after 9 are A, B, C, D, E. and F. The number after F, as you might guess, is 10 - decimal 16.
Nice little thread!
I'm currently having a similar problem -- but the other way around: I'm reading in strings from a POST HTTP response and have to decode the form variable's values. Unfortunately, a string value of "0,255,128" get's sent to the web server (running on the Arduino) as "0%2C255%2C128" because the comma character from the form's 'value=0,255,128' gets urlencoded to %2C.
Sooo, I have to decode HTML entities and was looking for a built-in (in some Arduino lib) function. To no avail.
The search function beamed me to this thread here.
Anybody who has a urldecode() function at hand that'll work on the Arduino?
Thanks so much!
Stefan.
Never mind!
Found something here: Google Code Archive - Long-term storage for Google Code Project Hosting.
Copy & pasted the two functions h2int() and urldecode() into my sketch and they work!
