Oh, I'm sure tons of people have written these. Here's mine. The sketch runs through a few sample URLs and feeds them into the parser.
const char *tests[] = {
"", // no parameters
"param1=test", // simple test
"param1=test¶m2=test2", // two parameters
"param1=test¶m2=test+2", // parameter with an encoded space
"param1=test¶m2=c%3A%5Cfoodir%5Cbarfile.fil", // percent encoding
"p1=1&p2=2&p3=3&p4=4&p5=5&p6=6&p7=7&p8=8" // more params than our test will acommodate
char buf[100];
char *params[5][2];
delay(5000);
for (int i = 0; i < sizeof(tests) / sizeof(*tests); i++) {
Serial.print("parsing \"");
Serial.print(tests[i]);
// copy test[i] into the buffer
// because the parser overwrites what is i the string it is passed.
strcpy(buf, tests[i]);
// parse the buffer into params[][]
int resultsCt = parseUrlParams(buf, params, 5, true);
// print off the results;
Serial.print("\" produced ");
Serial.print(resultsCt);
Serial.print(" parameters:");
for (int i = 0; i < resultsCt; i++) {
Serial.print("param ");
Serial.print(i);
Serial.print(" name \"");
Serial.print( params[i][0]);
Serial.print("\", param \"");
Serial.print( params[i][1]);
Serial.print("\".");
* queryString: the string with is to be parsed.
* WARNING! This function overwrites the content of this string. Pass this function a copy
* if you need the value preserved.
* results: place to put the pairs of param name/value.
* resultsMaxCt: maximum number of results, = sizeof(results)/sizeof(*results)
* decodeUrl: if this is true, then url escapes will be decoded as per RFC 2616
int parseUrlParams(char *queryString, char *results[][2], int resultsMaxCt, boolean decodeUrl) {
int ct = 0;
while (queryString && *queryString && ct < resultsMaxCt) {
results[ct][0] = strsep(&queryString, "&");
results[ct][1] = strchrnul(results[ct][0], '=');
if (*results[ct][1]) *results[ct][1]++ = '\0';
if (decodeUrl) {
percentDecode(results[ct][0]);
percentDecode(results[ct][1]);
ct++;
return ct;
* Perform URL percent decoding.
* Decoding is done in-place and will modify the parameter.
void percentDecode(char *src) {
char *dst = src;
while (*src) {
if (*src == '+') {
src++;
*dst++ = ' ';
else if (*src == '%') {
// handle percent escape
*dst = '\0';
src++;
if (*src >= '0' && *src <= '9') {
*dst = *src++ - '0';
else if (*src >= 'A' && *src <= 'F') {
*dst = 10 + *src++ - 'A';
else if (*src >= 'a' && *src <= 'f') {
*dst = 10 + *src++ - 'a';
// this will cause %4 to be decoded to ascii @, but %4 is invalid
// and we can't be expected to decode it properly anyway
*dst <<= 4;
*dst |= *src++ - '0';
*dst |= 10 + *src++ - 'A';
*dst |= 10 + *src++ - 'a';
dst++;
else {
*dst++ = *src++;
*dst = '\0';
