URM 37 Ultrasonic Sensor V3.2
	DistanceBySoftwareSerial.pde - URM 37 Control Library Version 2.0.0
 	Author: Miles Burton, miles@mnetcs.com
 	Copyright (c) 2009 Miles Burton All Rights Reserved
 	This library is free software; you can redistribute it and/or
 	modify it under the terms of the GNU Lesser General Public
 	License as published by the Free Software Foundation; either
 	version 2.1 of the License, or (at your option) any later version.
 	This library is distributed in the hope that it will be useful,
 	but WITHOUT ANY WARRANTY; without even the implied warranty of
 	MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
 	Lesser General Public License for more details.
 	You should have received a copy of the GNU Lesser General Public
 	License along with this library; if not, write to the Free Software
 	Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
#include "URMSerial.h"
// The measurement we're taking
#define DISTANCE 1
#define TEMPERATURE 2
#define ERROR 3
#define NOTREADY 4
#define TIMEOUT 5
URMSerial urm;
  Serial.begin(9600);                  // Sets the baud rate to 9600
  urm.begin(6,7,9600);                 // RX Pin, TX Pin, Baud Rate
  Serial.println("URM37 Library by Miles Burton - Distance. Version 2.0");   // Shameless plug
  Serial.println("Measurement: ");
  Serial.println(getMeasurement());  // Output measurement
int value; // This value will be populated
int getMeasurement()
  // Request a distance reading from the URM37
  switch(urm.requestMeasurementOrTimeout(DISTANCE, value)) // Find out the type of request
  case DISTANCE: // Double check the reading we recieve is of DISTANCE type
    //    Serial.println(value); // Fetch the distance in centimeters from the URM37
    return value;
  case TEMPERATURE:
    return value;
  case ERROR:
    Serial.println("Error");
  case NOTREADY:
    Serial.println("Not Ready");
  case TIMEOUT:
    Serial.println("Timeout");
  return -1;
Library from MilesBurton.com
Can the RX pin and the TX pin on the Arduino be changed from 6 and 7 to maybe 8 and 9 ? (refer to the code above)
Does the TX pin of the URM37 connected to the RX pin of the Arduino ? And also does the RX pin of the URM37 connected to the TX pin of the Arduino ?
I can't think of any special function of 6 and 7 that is being exploited, and if there were, I can't see why the library would allow you to change them, so I'd say, yes, you can changed them.
