What exactly do you expect from this line of code? You have a bunch of them in your code and I'm almost sure your expectations are wrong.
BTW: your code won't ever do anything reasonable. You might have to tell us what you think it should do.
hi im trying to send information to a pic18F1220 to turn leds on, ive re wrote the code to this
ive checked pin 11 its defintely sending the problem is the pic aint receiving
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11);
unsigned char PIR = 0;
unsigned char MIC = 0;
unsigned char REED = 0;
unsigned char ALARM = 0;
void setup(){
PIR = 0;
MIC = 0;
REED = 0;
ALARM = 0;
mySerial.write(0b0110);
if (PIR&MIC&REED&ALARM) {
mySerial.write(0b0111);
else if (MIC&REED&ALARM) {
else if (PIR&REED&ALARM) {
mySerial.write(0b0101);
else if (PIR&MIC&ALARM) {
mySerial.write(0b0100);
else if (PIR) {
mySerial.write(0b0001);
else if (MIC) {
mySerial.write(0b0010);
else if (REED) {
mySerial.write(0b0011);
delay(500); //wait for 500ms
PIC CODE
#include <htc.h>
#include <pic18.h>
#pragama config WDT=OFF, OSC=INTIO2,PWRT=ON, LVP=OFF, MCLRE=OFF
#include <plib/usart.h>
#include <delays.h>
int main(void) {
//Open Serial Port for Read Communication
OpenUSART(USART_RX_INT_OFF&
USART_TX_INT_OFF&
USART_ASYNCH_MODE&
USART_EIGHT_BIT&
USART_CONT_RX&
USART_BRGH_HIGH, 51);
CREN = 1;
ADCON1= 0x7F;
TRISA = 0x00; // set PortA to Output
//while(1) {
PORTAbits.RA0 = 1;
PORTAbits.RA1 = 1;
PORTAbits.RA2 = 1;
PORTAbits.RA3 = 1;
Delay100TCYx(78);
PORTAbits.RA0 = 0;
PORTAbits.RA1 = 0;
PORTAbits.RA2 = 0;
PORTAbits.RA3 = 0;
Delay100TCYx(78);
while(1){
while(!DataRdyUSART()); //wait until data is availiable on the USART
switch(ReadUSART()) { //Read from USART and test against table
case(0b0001): //
PORTAbits.RA0 = 1;
case(0b0010):
PORTAbits.RA1 = 1;
case(0b0011):
PORTAbits.RA2 = 1;
case(0b0100):
PORTAbits.RA0 = 1;
PORTAbits.RA1 = 1;
PORTAbits.RA3 = 1;
case(0b0101):
PORTAbits.RA0 = 1;
PORTAbits.RA2 = 1;
PORTAbits.RA3 = 1;
case(0b0110):
PORTAbits.RA1 = 1;
PORTAbits.RA2 = 1;
PORTAbits.RA3 = 1;
case(0b0111):
PORTAbits.RA0 = 1;
PORTAbits.RA1 = 1;
PORTAbits.RA2 = 1;
PORTAbits.RA3 = 1;
default:PORTA = 0;
//Delays10KTCYx(10); //wait for 500ms
LATA = 0; //Turn LEDs off
Since PIR, MIC, REED and ALARM are set to zero and never changed, the if's will never be true. The only mySerial.write() that is executed is the first one.
i know its group project the PIR REED MIC And ALARM isnt my bit of code, thats is done enought bit of code im simpley trying to get the arduino to send data to the pic, that first line was to check after i got that to work i would have change the others
so && is actually digital & yeah i beleive thats the one i need, but its still doesnt help that the arduino aint sending any data have hooked up to an oscilloscope and getting nothing
