USART2 Interrupt handler issue in SAM3X8e arduino due
Hi All,
I'm working with USART2 in arduino due. In which below mention my code,
System_Init();
USART2->US_THR = 's';
void USART2_Handler(void)
if (USART2->US_CSR & 0x00000001)
uint8_t in = USART2->US_RHR; // Read in received byte
if (in == 'b')
void System_Init(void)
// port peripheral initialization
WDT->WDT_MR = WDT_MR_WDDIS;
PIOB->PIO_IDR |= PIO_PB20_USTXD | PIO_PB21_USRXD ;
PIOB->PIO_PDR |= PIO_PB20_USTXD | PIO_PB21_USRXD ;
PIOB->PIO_ABSR &= ~(PIO_ABSR_TX_RX);
PIOB->PIO_PUER |= PIO_PB20_USTXD | PIO_PB21_USRXD;
PMC->PMC_PCER0 |= PMC_PERIPHERAL_ID;
USART2->US_CR = USART_CR_RSTRX | USART_CR_RSTTX | USART_CR_RXDIS | USART_CR_TXDIS;
USART2->US_MR = USART_MR_USCLKS | USART_MR_CHRL | USART_MR_SYNC | USART_MR_PAR | USART_MR_MSBF;
USART2->US_BRGR = USART_BRCD | USART_BRFP ;
NVIC_EnableIRQ(USART2_IRQn );
USART2->US_IER = 0x00000002 | 0x00000001 | 0x00000005 |0x00000006;
USART2->US_CR = USART_CR_RXEN | USART_CR_TXEN;
when I enable the receiver and transmitter in USART2, loop function isn't work. But when i send the data from PC to arduino due, it's work fine.. it mean the interrupt handler act also work fine.. But our main problem to be
1.why the Void loop() function isn't executed when i enable the transmitter and receiver in USART2?
2. How to activate both interrupt handler and loop function? check whether I miss any configuration on my code?
3. why the SAM3X8E controller goes to sleep mode when i enable the RX and TX?
Kindly give any suggestion for my problem.
Thanks & regards,
Poovai Anitha.L
Firstly you have to alter variant.h to write your own USART2 interrupt handler
Thank u. Kindly give any sample..
I modified the variant.c and header file for USART2. But I had receive continuous receiver interrupt. How can I resolved this issue ?
#include <variant.h>
init();
Serial4.begin(9600);
USART2->US_THR = ‘S’;
while((USART2->US_CSR & 0x000000002) == 0);
void serialEvent4()
if (Serial4.available())
USART2->US_THR = USART2->US_RHR;
continuously i get the serialevent4 interrupt. Please give solution for my issue…
Thanks & Regards,
Poovai Anitha.L
The DUE configuration initializes Serial, Serial1, Serial2 and Serial3. For Serial4 initialization, you need some extra lines of code (search example codes in the DUE sub forum for Serial4 initialization).
