USART_TX Interruption not entering (USART0_RXC)
Hello Guys, I'm having problems with USART to read one and more caracters by register.
My USART init function:
void Usart_interrupt_init(void)  // this function is correct
    //cli();
    UBRR0H = (BAUD_PRESCALER >> 8);
    UBRR0L =  BAUD_PRESCALER;
    UCSR0A &= ~(1 << U2X0);
    UCSR0B = ((1<<RXEN0)|(1<<TXEN0)|(1 << RXCIE0));
    UCSR0C = ((0<<USBS0)|(1 << UCSZ01)|(1<<UCSZ00));
    sei();
This is my code to read a single caracter. But when I try to read a caracter in main function sending by serial monitor, it only read when I type a caracter twice.
char Receive_Data(void) {
  while ( !( UCSR0A & (1 << RXC0)) ) {
  return UDR0;
This is my USART Interruption, but it seens the code never enter it.
#define RX_BUFFER_SIZE  128
volatile char rxBuffer[RX_BUFFER_SIZE];
volatile uint8_t rxReadPos = 0;
volatile uint8_t rxWritePos = 0;
// my code continues here
ISR(USART0_RXC)
    rxBuffer[rxWritePos] = UDR0;
    rxWritePos++;
    if(rxWritePos >= RX_BUFFER_SIZE)
        rxWritePos = 0;
// end of my code
When I try to print rxBuffer on main, nothing happens, like if I never entered in the interruption.
Obs: This function is working, but I need to programm by register and can't use it.
if(Serial.available() > 0)
    teste = Serial.read();
    printf("%c ",teste);
Please describe why you need to re-invent the wheel.
You should either use the RXC interrupt vector or check the RXC0 bit but not both. It might be that I interpret your code incorrectly but that's your fault, you posted excerpts instead of complete code. Post a complete sketch if you need more information.
