I have a PCB that I made for a remote power supply and monitoring system. I have an ESP32 chip on it that is to be programmed using a USB-UART port.
Since the system is remote, I have 12v to 5v regulators on the board as well to act as the external power supply. When I connect the USB cable, I get a notification that the power that my PCB has exceeded the power limits of the USB port.
What could be the issue? Is it the diode? or what did i miss out on in the design? I used the espressif wroom-32 schematic as a guide for my PCB.
Also what can I do to solve the issue? The PCB is due next week and was shipped in from China so I don't have much time.
I don't know off the top of my head, but you can either get it from your laptop, or look up the USB 2 or 3 whichever applies spec on-line.
Off the top of my head, 500 mA for USB 2 or 900 mA for USB 3. What does the PCB do? You designed it, so you should know. As a designer, you should own a current meter or, at a minimum, a VOM. I also use several varieties of USB-specific power measuring dongles.
there is an input from a 12V battery that is to be stepped down to 5V to power the ESP32 remotely. I haven't connected the battery yet because I wanted to upload my code onto the ESP through the USB.
