I'm having problems with compiling Mega ADK USB accessory example. I'm doing everyting mentioned here: Urządzenia peryferyjne i akcesoria Android | Android Open Source Project
But im getting compile errors:
In file included from C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/usb_drv.h:56:0,
from C:\Users\Marduk\Documents\Arduino\libraries\ADK2\accessory.c:19:
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:238:1: error: unknown type name 'Bool'
typedef Bool Status_bool_t; //!< Boolean status.
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:239:1: error: unknown type name 'U8'
typedef U8 Status_t; //!< 8-bit-coded status.
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:248:3: error: unknown type name 'S16'
S16 s16 ;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:249:3: error: unknown type name 'U16'
U16 u16 ;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:250:3: error: unknown type name 'S8'
S8 s8 [2];
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:251:3: error: unknown type name 'U8'
U8 u8 [2];
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:257:3: error: unknown type name 'S32'
S32 s32 ;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:258:3: error: unknown type name 'U32'
U32 u32 ;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:259:3: error: unknown type name 'S16'
S16 s16[2];
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:260:3: error: unknown type name 'U16'
U16 u16[2];
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:261:3: error: unknown type name 'S8'
S8 s8 [4];
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:262:3: error: unknown type name 'U8'
U8 u8 [4];
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:268:3: error: unknown type name 'S64'
S64 s64 ;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:269:3: error: unknown type name 'U64'
U64 u64 ;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:270:3: error: unknown type name 'S32'
S32 s32[2];
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:271:3: error: unknown type name 'U32'
U32 u32[2];
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:272:3: error: unknown type name 'S16'
S16 s16[4];
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:273:3: error: unknown type name 'U16'
U16 u16[4];
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:274:3: error: unknown type name 'S8'
S8 s8 [8];
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:275:3: error: unknown type name 'U8'
U8 u8 [8];
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:281:3: error: unknown type name 'S64'
S64 *s64ptr;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:282:3: error: unknown type name 'U64'
U64 *u64ptr;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:283:3: error: unknown type name 'S32'
S32 *s32ptr;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:284:3: error: unknown type name 'U32'
U32 *u32ptr;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:285:3: error: unknown type name 'S16'
S16 *s16ptr;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:286:3: error: unknown type name 'U16'
U16 *u16ptr;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:287:3: error: unknown type name 'S8'
S8 *s8ptr ;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:288:3: error: unknown type name 'U8'
U8 *u8ptr ;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:294:3: error: unknown type name 'S64'
volatile S64 *s64ptr;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:295:3: error: unknown type name 'U64'
volatile U64 *u64ptr;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:296:3: error: unknown type name 'S32'
volatile S32 *s32ptr;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:297:3: error: unknown type name 'U32'
volatile U32 *u32ptr;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:298:3: error: unknown type name 'S16'
volatile S16 *s16ptr;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:299:3: error: unknown type name 'U16'
volatile U16 *u16ptr;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:300:3: error: unknown type name 'S8'
volatile S8 *s8ptr ;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:301:3: error: unknown type name 'U8'
volatile U8 *u8ptr ;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:307:3: error: unknown type name 'S64'
const S64 *s64ptr;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:308:3: error: unknown type name 'U64'
const U64 *u64ptr;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:377:3: error: unknown type name 'U16'
const volatile U16 *u16ptr;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:378:3: error: unknown type name 'S8'
const volatile S8 *s8ptr ;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:379:3: error: unknown type name 'U8'
const volatile U8 *u8ptr ;
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/compiler.h:1221:1: error: unknown type name 'U8'
typedef U8 Byte; //!< 8-bit unsigned integer.
In file included from C:\Users\Marduk\Documents\Arduino\libraries\ADK2\accessory.c:19:0:
C:\Users\Marduk\Documents\Arduino\libraries\ADK2\utility/usb_drv.h:60:18: fatal error: chip.h: No such file or directory
#include "chip.h"
compilation terminated.
Error compiling.
Changing line
#include <ADK.h>
to
#include <C:\Users\Marduk\Documents\Arduino\libraries\ADK2\ADK.h>
fixes some problems but other errors are shown:
usbaccessory.cpp.o: In function `setup':
C:\Users\Marduk\Desktop\adk\arduino-1.6.5-r5/usbaccessory.ino:36: undefined reference to `ADK::adkSetPutchar(void (*)(char))'
C:\Users\Marduk\Desktop\adk\arduino-1.6.5-r5/usbaccessory.ino:37: undefined reference to `ADK::adkInit()'
C:\Users\Marduk\Desktop\adk\arduino-1.6.5-r5/usbaccessory.ino:40: undefined reference to `ADK::usbSetAccessoryStringVendor(char const*)'
C:\Users\Marduk\Desktop\adk\arduino-1.6.5-r5/usbaccessory.ino:41: undefined reference to `ADK::usbSetAccessoryStringName(char const*)'
C:\Users\Marduk\Desktop\adk\arduino-1.6.5-r5/usbaccessory.ino:42: undefined reference to `ADK::usbSetAccessoryStringLongname(char const*)'
C:\Users\Marduk\Desktop\adk\arduino-1.6.5-r5/usbaccessory.ino:43: undefined reference to `ADK::usbSetAccessoryStringVersion(char const*)'
C:\Users\Marduk\Desktop\adk\arduino-1.6.5-r5/usbaccessory.ino:44: undefined reference to `ADK::usbSetAccessoryStringUrl(char const*)'
C:\Users\Marduk\Desktop\adk\arduino-1.6.5-r5/usbaccessory.ino:45: undefined reference to `ADK::usbSetAccessoryStringSerial(char const*)'
C:\Users\Marduk\Desktop\adk\arduino-1.6.5-r5/usbaccessory.ino:47: undefined reference to `ADK::usbStart()'
usbaccessory.cpp.o: In function `loop':
C:\Users\Marduk\Desktop\adk\arduino-1.6.5-r5/usbaccessory.ino:100: undefined reference to `ADK::capSenseSlider()'
usbaccessory.cpp.o: In function `SendBuf::Send()':
C:\Users\Marduk\Desktop\adk\arduino-1.6.5-r5/usbaccessory.ino:57: undefined reference to `ADK::accessorySend(void const*, unsigned int)'
C:\Users\Marduk\Desktop\adk\arduino-1.6.5-r5/usbaccessory.ino:112: undefined reference to `ADK::accessoryReceive(void*, unsigned int)'
C:\Users\Marduk\Desktop\adk\arduino-1.6.5-r5/usbaccessory.ino:150: undefined reference to `ADK::ledDrawLetter(char, unsigned char, unsigned char, unsigned char, unsigned char)'
C:\Users\Marduk\Desktop\adk\arduino-1.6.5-r5/usbaccessory.ino:153: undefined reference to `ADK::adkEventProcess()'
collect2.exe: error: ld returned 1 exit status
Error compiling.
I have no idea what im doing wrong and how to fix this, any ideas?
