Hi.
I was reading about SoftwareSerial and it sounds like you could lose data when using it? Am I reading that right and is there any way around it? Like using an interrupt? My current need is to debug some software. I want to use the USB port to communicate with the Uno and to allow use of the serial monitor. The SoftwareSerial ports will be used to receive data from an Maxbotix XL- MaxSonar®- WR1?.
Here is a link to the sensor datasheet: http://www.coolcomponents.co.uk/resources/MAXBOTIX/XLWR1/MB7060-MB7070_Datasheet.pdf
Pin 5 outputs 5 bytes every 100 mS. Is it possible to capture this data without loss and use it in my app? I am not concerned with the TX pin since I only need data from the sensor. Is that an issue if I only write software for RX?
Thanks for any help!
