USB Beverage cooler
Beverge Cooler
I saw this and was wondering the best way to build my own. How do you think it is cooled? It would seem it uses a peltier because it is referred to as a “thermoelectric cooler” elsewhere and the similar model can heat as well as cool. Thanks :slight_smile:
Did you read the reviews?
you insert a warm soda and put it in the mini fridge overnight, in the morning you'll have a warm soda.
Maybe five degrees cooler than ambient room temperature. An absolute waste of money.
The device consumes 10 watts. It is impossible to cool effectively with such low power and so little insulation. 12 volt thermoelectric beverage coolers for autos have decent insulation and typically consume about 100 watts.
I found one of these at work - I concur, practically useless - and it stands to reason that is why I found it abandoned.
However the base does get cold if that interests you, but the laws of thermodynamics/heat transfer work very strongly against the intended purpose.
To answer your question:
'Peltier effect'
The reason I want to build one myself IS the negative reviews. I realize good insulation would required for such a low current model to do anything meaningful.
Excellent.
There is another factor: heat is energy.
If the insulation is perfect, 4 watts removed in 1 second will reduce the temperature of 1 gram (1 cubic centimeter) of water by 1 degree Celsius.
Peltier devices are typically around 5% efficient, which means you need 20 watts of electrical energy to achieve 1 watt of cooling.
Standard USB 2 ports are rated for 1/2 Amp (2.5W). USB 3 ports are rated for 0.9 Amps (4.5W).
I suggest you have a "plan B" with a better power source just in case you can't get nearly infinite insulation and in case you don't have a nearly infinite amount of time to cool the drink. :wink:
It is impossible to make an effective beverage cooler that is powered off of a USB power supply - the laws of physics dictate that more power than USB can supply is needed. By a lot - that 5% efficiency is a killer.
I don't plan on powering the final unit through USB, but i do want it to act as a small fridge.
Sorry, I didn't realise you adjust said peltier effect in your original post.
Are there no instructables or otherwise?
Heat is energy ?
Watts >> joules/s >> rate of energy transfer
Heat is energy ?
Yep, as stated, 4 watts for one second is 4 joules (~ 1 cal) of heat energy removed.
A more accurate conversion is 4.184 joules per cal.
Ugh,
Typing on a mobile has made a mess of my last post ...
adjust ??
also I was trying to point out the unit / rate difference between heat and heat transfer - but the question mark doesn't help :slight_smile:
One watt (rate of heat transfer) times one second = one Joule (of heat transferred).
I got a response from the distributor claiming it would take to long for them to test how fast they cool, I guess they don’t know how to ask the manufacturer for part numbers.
Google Search: Peltier Cooler Response Time
From what I can tell, and from personal experience, the response of the wafer is one factor, the volume of the cooler is the other factor. The first is almost instantaneous
(fractions of a second), the second factor depends on the size of the wafer with respect to the surface area of the cooler walls (ie: % of cooler surface area covered by peltier wafers)
