USB Communication between Arduino MEGA and external device
Hi all,
I'm trying to use my Arduino Mega to communicate with a light meter. Basically I need to send a serial command to the light meter so that Arduino can receive and read the measured data. I add a USB host shield and connect it with the light meter using USB cable.
However, it seems like the USB communication is much harder than RS232 communication. The device needs a FTDI driver as described in the Communication Specification(attached), meaning that I need to write a driver by myself. I found there is a FTDI Sketch Example included in the USB shield library, but I have no idea how it works and how should I modify it since I can't find any detailed explanation regarding this issue. As described in page 31 of the attached manual (communication method), the character length is 7 bits; Even Parity; 1 stop bit. So it is necessary to modify these parameters. Can anyone teach me how can I do that? Any help would be appreciated. Thank you so much.
Here is the Sketch included in the USB shield library:
#include <cdcftdi.h>
#include <usbhub.h>
#include "pgmstrings.h"
// Satisfy the IDE, which needs to see the include statment in the ino too.
#ifdef dobogusinclude
#include <spi4teensy3.h>
#endif
#include <SPI.h>
class FTDIAsync : public FTDIAsyncOper
public:
    uint8_t OnInit(FTDI *pftdi);
uint8_t FTDIAsync::OnInit(FTDI *pftdi)
    uint8_t rcode = 0;
    rcode = pftdi->SetBaudRate(115200);
    if (rcode)
        ErrorMessage<uint8_t>(PSTR("SetBaudRate"), rcode);
        return rcode;
    rcode = pftdi->SetFlowControl(FTDI_SIO_DISABLE_FLOW_CTRL);
    if (rcode)
        ErrorMessage<uint8_t>(PSTR("SetFlowControl"), rcode);
    return rcode;
USB              Usb;
//USBHub         Hub(&Usb);
FTDIAsync        FtdiAsync;
FTDI             Ftdi(&Usb, &FtdiAsync);
  Serial.begin( 115200 );
#if !defined(__MIPSEL__)
  while (!Serial); // Wait for serial port to connect - used on Leonardo, Teensy and other boards with built-in USB CDC serial connection
#endif
  Serial.println("Start");
  if (Usb.Init() == -1)
      Serial.println("OSC did not start.");
  delay( 200 );
    Usb.Task();
    if( Usb.getUsbTaskState() == USB_STATE_RUNNING )
        uint8_t  rcode;
        char strbuf[] = "DEADBEEF";
        //char strbuf[] = "The quick brown fox jumps over the lazy dog";
        //char strbuf[] = "This string contains 61 character to demonstrate FTDI buffers"; //add one symbol to it to see some garbage
        Serial.print(".");
        rcode = Ftdi.SndData(strlen(strbuf), (uint8_t*)strbuf);
	if (rcode)
            ErrorMessage<uint8_t>(PSTR("SndData"), rcode);
        delay(50);
        uint8_t  buf[64];
        for (uint8_t i=0; i<64; i++)
            buf[i] = 0;
        uint16_t rcvd = 64;
        rcode = Ftdi.RcvData(&rcvd, buf);
        if (rcode && rcode != hrNAK)
            ErrorMessage<uint8_t>(PSTR("Ret"), rcode);
        // The device reserves the first two bytes of data
        //   to contain the current values of the modem and line status registers.
        if (rcvd > 2)
            Serial.print((char*)(buf+2));
        delay(10);
cl-200a_cs0101e_eng comms specifications.pdf (415 KB)
Also, is it possible to use Tx1 & Rx1 port of Arduino MEGA to connect with the USB port of the device ? (with USB to TTL converter between these two devices)
