USB communication OK, but no voltage??
Hi everyone,
this morning using my arduino, I connected it to my PC with USB and it started, but after a few seconds stopped working and LEDS were off.
Now the Arduino doesnt start if only using USB.
If i use a extern Current (12v-Adapter or Vin pin) the Ardu starts properly and if I connect it now to the PC with USB, it works fine, no problems with serial communication.
What can be the problem??
Thanks in advance
Connect USB stick "flash memory" to that port check if work or not
For me it seems you Brock your USB, not sure maybe! :stuck_out_tongue:
Nop, it is not broken ;D . I tried it though. The Ardu doesnt start only with Usb in any other Computer also.
Then I don't know :stuck_out_tongue: not happened to me before
wait someone to help you :wink:
riffraff:
USB cable.
