Hi
I am using SAMD21( Xiao) board. I want to use it's native USB as a live data capturing(data logger) in Microsoft Excel. I found a article in Microsoft article link is below. but it is only for UART with FTDI based USB(like NodeMCU). Please help me in work same with SAMD21 native USB port.
Are you sure? I couldn't see any reference to an FTDI based USB serial interface on the Microsoft data streamer add-in site.
There is also another piece of code called PLX-DAQ which can get data into Excel. There's a forum topic on it here:
There's probably other web resources on how to use it as well.
Hi
Thanks for your support.
To test Microsoft data streamer Addin, I flashed the same piece code into NodeMCU and seedstudio Xiao SAMD21. In there only NodeMCU is working. So I suspected the FTDI chip.
I tried PLX-DAQ version 2 not working
PLX-DAQ is not working showing below
With 570+ posts in the PLX-DAQ thread, i'm hopefull that you can get a reply as to why it doesn't work for you.
PLX-DAQ is not working that's why i moved to inbuilt Excel build it addon of data streamer but it is only working for NodeMCU not SAMD21 Xiao board.
Please suggest other way to capture live data in Excel sheet..
After long struggle, i found this one to capture live data from Xiao SAMD21.
