USB FILES (PDF)
Hi Sir,
Is it possible to view the files of the flash drive (USB) in the UTFT??
Thanks, Charles
yes
john1993: yes
Alright! Thanks sir. Can you give me sample wiring and codes? :)
i implemented a host reader using AT90USB1287 with lufa library and 2.2" ili9341 but unfortunately only my client owns the rights to source. the good news is this chip is very cheap and easy to find (40 cents chinese seller). afaik there are no arduino sketches but i did use the gcc compiler from ardunio. it is not a job for beginners. sd card is much easier and only took a few minutes to run. usb host on avr took me couple hundred man hours.
also should mention the standard adafruit gfx tft library had some advantages over utft. in any case google is your friend.
