USB Flash Drive Disconnect after 20 Seconds
The main loop of USBHOSTMBED5 example FileRead indicates msd.connect as not connected after 20-30 seconds and never reconnects even though there is an attempt to reconnect.
// handle disconnection and reconnection
if (!msd.connected()) {
msd.connect();
The file read performed in the setup does work but the issue is how to keep the FileSystem connected.
Thanks
Jim
Not sure what you mean by:
First, hopefully you are using USBHostMbed5 version 3.1. Use the library manager to check/upgrade. Next change:
        msd.connect();
To:
Serial.print("msd.connected() is returning");
Serial.println(msd.connected());
        msd.connect();
msd.connected() is returning 1
msd.connected() is returning 0
The above was me unplugging and replugging the USB stick. As you can see it is reconnecting :wink:
I let the sketch run for several minutes and it never showed any disconnection. How did you determine that it was disconnecting after 20-30 seconds?
Here is what I get for your code.....
Mounting USB device...
read done Open /usb/numbers.txt
Writing numbers (0/10)
Writing numbers (1/10)
Writing numbers (2/10)
Writing numbers (3/10)
Writing numbers (4/10)
Writing numbers (5/10)
Writing numbers (6/10)
Writing numbers (7/10)
Writing numbers (8/10)
Writing numbers (9/10)
File closing
File closed
msd.connected() is returning1
msd.connected() is returning0
Your original post said you were using "FileRead". That is what I tested. I will have to check the FileWrite.ino sketch...
Back with results:
File closing
File closed
And it stays connected until I unplug the USB stick. You might want to try another Fat32 formatted USB stick or maybe reformat the one you are using. Right now I have one that has two partitions on it. If I access partition #1 it works fine, but if I try to access partition #2 the whole thing disconnects. I am trying to recover it but I am not having much success :slightly_frowning_face:
Probably no good...
EDIT: Try the USB stick on a regular PC and see if it disconnects.
You are correct in that I selected File Write instead File Read example...Sorry.
I did find that two out of 4 USB flash drives worked and the other two did not.
All 4 USB flash drives work flawlessly on a Windows PC.
Note... All 4 USB Flash drives were under 32gb, formatted MRB.
Hi @tyrrellaz,
Please try reformatting again your USB in FAT32 as suggested by @wwatson. I have tried to replicate it but it is working fine for me without disconnecting.
Thank you for your contribution!
I have tested four USB Flash Drives all FAT32 MBR configured and only 2 of the drives work and remain connected. Appears that some other criteria is required beyond FAT32 MBR.
I have 3 different types of SanDisk and one Verbatim.
Jim
Solution: The USB-A power switch had failed causing power to the USB flash drive to drop after 20 seconds of on time.
