USB Host Shield + Barcode Scanner
Hello all,
I just purchased this USB Host Shield: https://www.sparkfun.com/products/9947 and I've connected it to a barcode scanner (the Taotronics TT-BS003: http://www.amazon.com/electronics/dp/B006LVO56W).
I'm trying to run the code example from this tutorial on my Arduino, but it doesn't seem to be working: http://www.circuitsathome.com/mcu/connecting-barcode-scanner-arduino-usb-host-shield I keep getting the error message: "expected class name before '{' token," and it highlights Line #59. Anybody understand what's going on? I've installed all the libraries and copied them into the project folder, too.
Thanks!
Never mind, I just noticed that I didn't download or install Arduino.h, inttypes.h, avr/pgmspace.h, or confdescparser.h. Gonna install those libraries and report back to y'all.
I just installed confdescparser.h, and I'm not quite sure how to acquire the other three, or if I already have them and I just don't know it. Still getting the exact same error. Thoughts?
Also, when I try to run the program USB_desc.pde from this library, the code won't compile: GitHub - felis/USB_Host_Shield_2.0: Revision 2.0 of USB Host Library for Arduino.
It says "Error compiling" and:
"In file included from USB_desc.pde:5:
/Users/ahhreeyell/Documents/Arduino/libraries/Usb/Usb.h:41:21: error: message.h: No such file or directory"
What's going on?
can some one help me, please! why when I connect all circuit based on http://www.circuitsathome.com/mcu/connecting-barcode-scanner-arduino-usb-host-shield and get some error.. when do compiling and they said usb does have not support!. i newer for arduino..please!
I can't. I can't understand you, and you left a lot out of your post.
What code? What errors?
Who is they? Doesn't have support for what?
What? If this means that you are new to Arduino, then writing drivers for USB devices is NOT what you should be doing.
