USB host shield Gamepad Serial communication - this could be huge!
So I have been researching for weeks on how to use a USB host shield to read data from an attached HID device as serial data that can be used by the SoftwareSerial or Serial libraries, allowing users to connect a USB gamepad or joystick without breaking it open and re-wiring it directly to Arduino pins.
I found this article: https://www.circuitsathome.com/mcu/hid-joystick-code-sample/
which seemed to have some good information, along with some other posts on this forum where people much more skilled than me seem to have thrown in the towel on this and broken their controller open. I know there is another way, and maybe with the infinite knowledge of some of the poeple on these forums we can figure it out!
here is a snippet of the code i'm using to control my project that works when using my HC-05 and SoftwareSerial libraries:
#define  DIR_UP    1
#define  DIR_DOWN  2
#define  DIR_LEFT  3
#define  DIR_RIGHT 4
/* *** Bluetooth controller button defines and input method *** */
#define  BTN_NONE  0
#define  BTN_UP    1
#define  BTN_DOWN  2
#define  BTN_LEFT  3
#define  BTN_RIGHT  4
#define  BTN_START  5
#define  BTN_EXIT  6
uint8_t curControl = BTN_NONE;
SoftwareSerial bluetooth(10, 11);
void readInput(){
  if (bluetooth.available() > 0) {
    // read the incoming byte:
    uint8_t incomingByte = bluetooth.read();
    Serial.println(incomingByte);
      switch(incomingByte){
        case 238:
          curControl = BTN_LEFT;
        case 239:
          curControl = BTN_RIGHT;
        case 236:
          curControl = BTN_UP;
        case 237:
          curControl = BTN_DOWN;
        case 224:
          curControl = BTN_START;
        case 225:
          curControl = BTN_EXIT;
I also found this code in the Examples of the USBHostShield 2.0 library UsbhidJoystick to collect incoming signal data from my USB gamepad using the host shield:
#include <usbhid.h>
#include <hiduniversal.h>
#include <usbhub.h>
// Satisfy IDE, which only needs to see the include statment in the ino.
#ifdef dobogusinclude
#include <spi4teensy3.h>
#include <SPI.h>
#endif
#include "hidjoystickrptparser.h"
USB Usb;
USBHub Hub(&Usb);
HIDUniversal Hid(&Usb);
JoystickEvents JoyEvents;
JoystickReportParser Joy(&JoyEvents);
#if !defined(__MIPSEL__)
        while (!Serial); // Wait for serial port to connect - used on Leonardo, Teensy and other boards with built-in USB CDC serial connection
#endif
        Serial.println("Start");
        if (Usb.Init() == -1)
                Serial.println("OSC did not start.");
        delay(200);
        if (!Hid.SetReportParser(0, &Joy))
                ErrorMessage<uint8_t > (PSTR("SetReportParser"), 1);
        Usb.Task();
When I connected the gamepad, i wrote down the commands that came in via Serial Monitor for each button pressed. Each button yielded 2 lines of coordinates in this format:
right  X1: 01	Y1: 7F	X2: 7F	Y2: FF	Rz: 7F
       X1: 01	Y1: 7F	X2: 7F	Y2: 7F	Rz: 7F
up     X1: 01	Y1: 7F	X2: 7F	Y2: 7F	Rz: 00
My question is, does anyone know how to convert this incoming data from the USB controller into the simple BTN_Down or DIR_down commands needed to control the program? I am trying to cannibalize the example code into my project as it seems to illustrate that the Host Shield is receiving consistent data from the controller, now I just need to program my project to read the USB data like the example code and convert the coordinate input data into the 7 simple BTN or DIR commands needed for the project. I am open to reposting this, but still fairly new to the forums and even newer to Arduino programming. Anyone have any ideas or should I throw in the towel like so many have before me?
If anyone needs any further code, let me know. I'll add to this post later. Thanks
Since it seems i may be talking to myself, I'll add in some further information I found. In searching, it looks like some people were suggesting possibly using a USB Host controller board (here) which claims to require no usb coding, and says it would send serial data to the Arduino. does anyone have any experience using a device like this? If I replaced my Host Shield with this, do you think it could work?
I started yesterday exactly the same project, using a PIC similar to that one in your latest post :slight_smile:
(and yes, I believe in karma too)
