USB Host Shield Library 2.0 and mega ADK
Hi all,
I'm having trouble using the USB Host Shield Library 2.0 from http://www.circuitsathome.com/ (repo is here https://github.com/felis/USB_Host_Shield_2.0) and I'm looking for some pointers/ tips etc
I am using an arduino mega ADK and am trying to connect with a slave device over usb. I am finding that the connection is really difficult to obtain and only works a small amount of the time. For now, I am just looking at the USBFTDILoopback example included in the repo. In the sketch I have only changed the baud rates and the message I wish to send. I have set the mega adk define in settings.h to 1, changed the number of LUN devices to 1 and enabled spi4teensy3 driver.
#define USE_UHS_MEGA_ADK 1
#ifndef MASS_MAX_SUPPORTED_LUN
#define MASS_MAX_SUPPORTED_LUN 1 //8
#endif
// Set to 1 to use the faster spi4teensy3 driver.
#ifndef USE_SPI4TEENSY3
#define USE_SPI4TEENSY3 1
#endif
When I do get it to connect this it what I get printed
Start
FTDI Init
Addr:01
NC:01
0000: 09 02 20 00 01 01 00 A0 2D 09 04 00 00 02 FF FF
0010: FF 02 07 05 81 02 40 00 00 07 05 02 02 40 00 00
Conf.Val: 01
Iface Num: 00
Alt.Set: 00
Endpoint descriptor:
Length:     07
Type:       05
Address:    81
Attributes: 02
MaxPktSize: 0040
Poll Intrv: 00
Conf.Val: 01
Iface Num: 00
Alt.Set: 00
Length:     07
Type:       05
Address:    02
Attributes: 02
MaxPktSize: 0040
Poll Intrv: 00
NumEP:03
Conf:01
baud_value:809C
baud_index:0000
FTDI configured
I can then send my command and receive a correct reply with no issues.
Most of the time however, the USBTaskState is 0xA0 (USB_STATE_ERROR) and I dont get any connection. As far as I can tell this gets raised in usb.Task() after running usb.Configuring().
Some of the time it will also just hang or get stuck in some other state.
I have tried disabling the spi4teensy3 driver but then I can't connect at all.
when i run the USB descr sketch I get the following
Device descriptor:
Descriptor Length:  12
Descriptor type:    01
USB version:        0200
Device class:       00
Device Subclass:    00
Device Protocol:    00
Max.packet size:    08
VendorĀ  ID:        0403
Product ID:     6001
Revision ID:        0600
Mfg.string index:   01
Prod.string index:  02
Serial number index:    03
Number of conf.:    01
Configuration descriptor:
Total length:       0020
Num.intf:       01
Conf.value:     01
Conf.string:        00
Attr.:          E0
Max.pwr:        00
Interface descriptor:
Intf.number:        00
Alt.:           00
Endpoints:      02
Intf. Class:        FF
Intf. Subclass:     FF
Intf. Protocol:     FF
Intf.string:        02
Endpoint address:   81
Attr.:          02
Max.pkt size:       0040
Polling interval:   00
Endpoint address:   02
Attr.:          02
Max.pkt size:       0040
Addr:1(0.0.1)
What am I doing wrong? is there something else I need to change/enable/edit somewhere to get the code to work reliably?
Also, as a side question: sometimes when using a library I have written to communicate with my usb device, along with a bunch of other code that's running, my code restarts. I'm guessing it's an issue with RAM or with my arrays because when I don't use USB everything runs fine. Do you have any suggestions for reducing RAM usage with USB? I don't use the String class, command strings are stored as const uint8_t arrays
Thanks for any help
Hi, I am with a similar problem, when I run the "USB_desc" example, appears on serial monitor: Start
01
Device descriptor: Descriptor Length: 12 Descriptor type: 01 USB version: 0110 Device class: 00 Device Subclass: 00 Device Protocol: 00 Max.packet size: 08 Vendor ID: 1267 Product ID: 0000 Revision ID: 0000 Mfg.string index: 00 Prod.string index: 00 Serial number index: 00 Number of conf.: 01
Configuration descriptor: Total length: 0019 Num.intf: 01 Conf.value: 01 Conf.string: 00 Attr.: 80 Max.pwr: 32
Interface descriptor: Intf.number: 00 Alt.: 00 Endpoints: 01 Intf. Class: FF Intf. Subclass: 00 Intf. Protocol: 00 Intf.string: 00
Endpoint descriptor: Endpoint address: 81 Attr.: 03 Max.pkt size: 0008 Polling interval: 08
Addr:1(0.0.1)
I want to comunicate with a USB Universal Device (ELAN USB Interface), but I dont know that example I will must to use. Help me please! Thank you in advance! Best regards,
AJoao
