usb host shield problem
hello. I was doing a research about arduino product with Wii remote. I use usb host shield to connect between arduino mega and Wii remote. The communication using bluetooth dongle. I use the program and library from Kristian Sloth Lauszus. Main point is the Wii remote can not send command. but i was succed paring it. I attach an image to describe my problem. So how to fix this?
So you have a USB host shield in order to connect to a bluetooth USB dongle in order to connect to a Wii?
Is it not possible to use a serial Bluetooth module and remove the shield from the system?
Thats right. Usb host shield has function to make communication with bluetooth between arduino and wii remote be possible. The dongle connect to usb plugs. Then usb host shield connect some pin output of arduino.
I have seen another project and it has happened. I think use usb host shield make more flexible for beginner as i am.
