USB host Shield Problem
Hello,
I want to make a project barcode scanning device, in which barcode scanner scans the barcode then sends it to mobile app.
The basic flow is as follows:
Barcode scanner → USB host sheld → Arduino Mega 2560 → Bluetooth module HC-05 → Mobile app.
I took the code from www.electroingenio.com
But there is some error which i can’t understand so plz help.
Code:
/* ****************************** www.electroingenio.com **********************************/
#include <hid.h> //Add to Oleg Mazurov code to Bar Code Scanner
#include <hiduniversal.h> //Add to Oleg Mazurov code to Bar Code Scanner
#include <usbhub.h>
#include <avr/pgmspace.h>
#include <Usb.h>
#include <usbhub.h>
#include <hidboot.h>
USB Usb;
USBHub Hub(&Usb); //I enable this line
String codeString;
char z;
int cont = 0;
String readString;
HIDUniversal Hid(&Usb); //Add this line so that the barcode scanner will be recognized, I use “Hid” below
HIDBoot<HID_PROTOCOL_KEYBOARD> Keyboard(&Usb);
class KbdRptParser : public KeyboardReportParser
void PrintKey(uint8_t mod, uint8_t key); // Add this line to print character in ASCII
protected:
virtual void OnKeyDown (uint8_t mod, uint8_t key);
virtual void OnKeyPressed(uint8_t key);
void KbdRptParser::OnKeyDown(uint8_t mod, uint8_t key)
uint8_t c = OemToAscii(mod, key);
if (c)
OnKeyPressed(c);
/* what to do when symbol arrives */
void KbdRptParser::OnKeyPressed(uint8_t key)
static uint32_t next_time = 0; //watchdog
static uint8_t current_cursor = 0; //tracks current cursor position
z=((char)key); // Read characters that arrive from serial port
codeString += z; //each character builds in a string
cont = cont+1;
if (char(key)== 19) { //verify the las digit of the scanner
codeString.remove(cont-1); //Remove the last digit
Serial.println(codeString); //Printing the complete code
codeString=""; // Clear string codestring
cont=0; // Reset the counter
KbdRptParser Prs;
Serial.begin( 9600 );
Serial.println(“Start”);
if (Usb.Init() == -1) {
Serial.println(“OSC did not start.”);
Hid.SetReportParser(0, (HIDReportParser*)&Prs); //Here I change “Keyboard” for “Hid”
delay( 200 );
Usb.Task();
Error:
In file included from C:\Users\d\Documents\Arduino\BCS_ardu\BCS_ardu.ino:4:0:
C:\Users\d\Documents\Arduino\libraries\USB_Host_Shield_20/hid.h:165:2: error: ‘USBHost’ does not name a type
USBHost *pUsb; // USB class instance pointer
C:\Users\d\Documents\Arduino\libraries\USB_Host_Shield_20/hid.h:182:14: error: expected ‘)’ before ‘*’ token
HID(USBHost *pusb) : pUsb(pusb) {};
C:\Users\d\Documents\Arduino\libraries\USB_Host_Shield_20/hid.h:184:8: error: ‘USBHost’ does not name a type
const USBHost* GetUsb() { return pUsb; };
In file included from C:\Users\d\Documents\Arduino\libraries\USB_Host_Shield_20/hiduniversal.h:21:0,
from C:\Users\d\Documents\Arduino\BCS_ardu\BCS_ardu.ino:5:
C:\Users\d\Documents\Arduino\libraries\USB_Host_Shield_20/usbhid.h:119:8: error: redefinition of ‘struct HidItemPrefix’
struct HidItemPrefix {
C:\Users\d\Documents\Arduino\libraries\USB_Host_Shield_20/hid.h:98:8: error: previous definition of ‘struct HidItemPrefix’
struct HidItemPrefix // Not used
C:\Users\d\Documents\Arduino\libraries\USB_Host_Shield_20/usbhid.h:125:8: error: redefinition of ‘struct MainItemIOFeature’
struct MainItemIOFeature {
C:\Users\d\Documents\Arduino\libraries\USB_Host_Shield_20/hid.h:131:8: error: previous definition of ‘struct MainItemIOFeature’
struct MainItemIOFeature // Not used
C:\Users\d\Documents\Arduino\libraries\USB_Host_Shield_20/usbhid.h:138:7: error: redefinition of ‘class HIDReportParser’
class HIDReportParser {
C:\Users\d\Documents\Arduino\libraries\USB_Host_Shield_20/hid.h:150:7: error: previous definition of ‘class HIDReportParser’
BCS_ardu:62: error: cannot declare variable ‘Prs’ to be of abstract type ‘KbdRptParser’
KbdRptParser Prs;
C:\Users\d\Documents\Arduino\BCS_ardu\BCS_ardu.ino:26:7: note: because the following virtual functions are pure within ‘KbdRptParser’:
C:\Users\d\Documents\Arduino\libraries\USB_Host_Shield_20/hid.h:153:15: note: virtual void HIDReportParser::Parse(HID*, bool, uint32_t, uint8_t*)
virtual void Parse(HID *hid, bool is_rpt_id, uint32_t len, uint8_t *buf) = 0;
In file included from C:\Users\d\Documents\Arduino\BCS_ardu\BCS_ardu.ino:11:0:
C:\Users\d\Documents\Arduino\libraries\USB_Host_Shield_20/hidboot.h: In instantiation of ‘uint8_t HIDBoot<BOOT_PROTOCOL>::Poll() [with unsigned char BOOT_PROTOCOL = 1u; uint8_t = unsigned char]’:
C:\Users\d\Documents\Arduino\BCS_ardu\BCS_ardu.ino:82:1: required from here
C:\Users\d\Documents\Arduino\libraries\USB_Host_Shield_20/hidboot.h:595:41: error: no matching function for call to ‘HIDReportParser::Parse(USBHID*, int, uint8_t, uint8_t [16])’
pRptParser->Parse((USBHID*)this, 0, (uint8_t)read, buf);
    C:\Users\d\Documents\Arduino\libraries\USB_Host_Shield_20/hidboot.h:595:41: note: candidate is:
    C:\Users\d\Documents\Arduino\libraries\USB_Host_Shield_20/hid.h:153:15: note: no known conversion for argument 1 from ‘USBHID*’ to ‘HID*’
    exit status 1
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.. :slight_smile:
You also need to tell us where you got that library.
