USB Host Shield - Problems with Code from Felis-Github
I recently purchased a USB Host Shield from sparkfun electronics. I have soldered all the connections and now i was trying to check for the code. I tried to complie the code but it gives me a bunch of errors. I will provide the below mentioned examples
I downloaded the library from the below mentioned link
and then i placed it with the name of USBHostShield1 at the below mentioned location in my arduino folder
Desktop\arduino-1.0\libraries\UsbHostShield1
Then i opened up the arduino software and opened the below mentioned sketch
When I compiled it, I got a bunch of errors mostly from the header files
descriptor_parser.cpp:2:17: error: Spi.h: No such file or directory
descriptor_parser.cpp: In function 'void setup()':
descriptor_parser.pde:-1: error: 'class MAX3421E' has no member named 'powerOn'
descriptor_parser.cpp: In function 'byte getdevdescr(byte)':
descriptor_parser.pde:-1: error: invalid conversion from 'char*' to 'uint8_t*'
descriptor_parser.pde:-1: error: initializing argument 4 of 'uint8_t USB::getDevDescr(uint8_t, uint8_t, uint16_t, uint8_t*)'
descriptor_parser.cpp: In function 'byte getstrdescr(byte, byte)':
descriptor_parser.pde:-1: error: initializing argument 6 of 'uint8_t USB::getStrDescr(uint8_t, uint8_t, uint16_t, uint8_t, uint16_t, uint8_t*)'
descriptor_parser.cpp: In function 'byte getconfdescr(byte, byte)':
descriptor_parser.pde:-1: error: initializing argument 5 of 'uint8_t USB::getConfDescr(uint8_t, uint8_t, uint16_t, uint8_t, uint8_t*)'
descriptor_parser.cpp: In function 'void printhid_descr(char*)':
descriptor_parser.pde:-1: error: 'bmREQ_HIDREPORT' was not declared in this scope
descriptor_parser.pde:-1: error: 'HID_DESCRIPTOR_REPORT' was not declared in this scope
descriptor_parser.pde:-1: error: 'USB_NAK_LIMIT' was not declared in this scope
descriptor_parser.cpp: At global scope:
descriptor_parser.cpp: In function 'byte ctrlXfer(byte, byte, byte, byte, byte, byte, unsigned int, uint16_t, void ()(uint8_t), uint16_t)':
descriptor_parser.pde:-1: error: 'EP_RECORD' was not declared in this scope
descriptor_parser.pde:-1: error: 'ep_rec' was not declared in this scope
descriptor_parser.pde:-1: error: 'class USB' has no member named 'getDevTableEntry'
' to 'uint8_t*'
descriptor_parser.pde:-1: error: initializing argument 3 of 'uint8_t* MAX3421e<SS, INTR>::bytesWr(uint8_t, uint8_t, uint8_t*) [with SS = TPin<Portb, 2u>, INTR = TPin<Portb, 1u>]'
descriptor_parser.cpp: In function 'void printProgStr(const char*)':
descriptor_parser.pde:-1: error: 'BYTE' was not declared in this scope
As of Arduino 1.0, the 'BYTE' keyword is no longer supported.
Please use Serial.write() instead.
Then I tried the USB Host Shield 2.0 and I tried to compile a sample example by the name of USB_DESC and I got the below mentioned errors
In file included from \arduino-1.0\libraries\UsbHostShield1\Max3421e.cpp:4:Desktop\arduino-1.0\libraries\UsbHostShield1/Max3421e.h:9:22: error: WProgram.h: No such file or directory
IDesktop\arduino-1.0\libraries\UsbHostShield1\Max3421e.cpp:4:
Desktop\arduino-1.0\libraries\UsbHostShield1/Max3421e.h:16: error: 'byte' does not name a type
Desktop\arduino-1.0\libraries\UsbHostShield1/Max3421e.h:18: error: 'byte' has not been declared
Desktop\arduino-1.0\libraries\UsbHostShield1/Max3421e.h:19: error: expected ';' before '(' token
Desktop\arduino-1.0\libraries\UsbHostShield1/Max3421e.h:20: error: 'byte' has not been declared
Desktop\arduino-1.0\libraries\UsbHostShield1/Max3421e.h:21: error: 'byte' does not name a type
Desktop\arduino-1.0\libraries\UsbHostShield1/Max3421e.h:22: error: expected ';' before '(' token
Desktop\arduino-1.0\libraries\UsbHostShield1/Max3421e.h:23: error: 'byte' does not name a type
Desktop\arduino-1.0\libraries\UsbHostShield1/Max3421e.h:24: error: 'boolean' does not name a type
Desktop\arduino-1.0\libraries\UsbHostShield1/Max3421e.h:25: error: 'boolean' does not name a type
Desktop\arduino-1.0\libraries\UsbHostShield1/Max3421e.h:28: error: 'byte' does not name a type
Desktop\arduino-1.0\libraries\UsbHostShield1/Max3421e.h:29: error: 'byte' does not name a type
Desktop\arduino-1.0\libraries\UsbHostShield1/Max3421e.h:30: error: 'byte' does not name a type
Desktop\arduino-1.0\libraries\UsbHostShield1/Max3421e.h: In static member function 'static void MAX3421E::spi_init()':
Desktop\arduino-1.0\libraries\UsbHostShield1/Max3421e.h:33: error: 'uint8_t' was not declared in this scope
Desktop\arduino-1.0\libraries\UsbHostShield1/Max3421e.h:33: error: expected `;' before 'tmp'
Desktop\arduino-1.0\libraries\UsbHostShield1/Max3421e.h:35: error: 'OUTPUT' was not declared in this scope
Desktop\arduino-1.0\libraries\UsbHostShield1/Max3421e.h:35: error: 'pinMode' was not declared in this scope
Desktop\arduino-1.0\libraries\UsbHostShield1/Max3421e.h:37: error: 'INPUT' was not declared in this scope
Desktop\arduino-1.0\libraries\UsbHostShield1/Max3421e.h:39: error: 'HIGH' was not declared in this scope
Desktop\arduino-1.0\libraries\UsbHostShield1/Max3421e.h:39: error: 'digitalWrite' was not declared in this scope
Desktop\arduino-1.0\libraries\UsbHostShield1/Max3421e.h:41: error: 'SPCR' was not declared in this scope
Desktop\arduino-1.0\libraries\UsbHostShield1/Max3421e.h:42: error: 'SPSR' was not declared in this scope
Desktop\arduino-1.0\libraries\UsbHostShield1/Max3421e.h:44: error: 'tmp' was not declared in this scope
Desktop\arduino-1.0\libraries\UsbHostShield1/Max3421e.h:45: error: 'SPDR' was not declared in this scope
Desktop\arduino-1.0\libraries\UsbHostShield1\Max3421e.cpp: At global scope:
Desktop\arduino-1.0\libraries\UsbHostShield1\Max3421e.cpp:7: error: 'byte' does not name a type
\arduino-1.0\libraries\UsbHostShield1\Max3421e.cpp: In constructor 'MAX3421E::MAX3421E()':
\arduino-1.0\libraries\UsbHostShield1\Max3421e.cpp:15: error: 'INPUT' was not declared in this scope
\Desktop\arduino-1.0\libraries\UsbHostShield1\Max3421e.cpp:15: error: 'pinMode' was not declared in this scope
\Desktop\arduino-1.0\libraries\UsbHostShield1\Max3421e.cpp:17: error: 'OUTPUT' was not declared in this scope
Desktop\arduino-1.0\libraries\UsbHostShield1\Max3421e.cpp:18: error: 'HIGH' was not declared in this scope
Please help in guiding me where am i going wrong. The code has been used by a number of people so it must be right ?
