Salve a tutti,
Ho una usb shield montata su un Arduino Mega a cui devo collegare un gps usb.
Ho scaricato la libreria usb host ed il codice relativo al acm funziona e mi fa vedere la stringa nmea.
Il problema sorge che non riesco a memorizzare tale stringa in una variabile di tipo String letturaGps necessaria per continuare le elaborazioni. Vi allego il codice sperando in un Vs aiuto.
#include <cdcacm.h>
#include <usbhub.h>
#include "pgmstrings.h"
// Satisfy the IDE, which needs to see the include statment in the ino too.
#ifdef dobogusinclude
#include <spi4teensy3.h>
#endif
#include <SPI.h>
class ACMAsyncOper : public CDCAsyncOper
public:
uint8_t OnInit(ACM *pacm);
uint8_t ACMAsyncOper::OnInit(ACM *pacm)
uint8_t rcode;
// Set DTR = 1 RTS=1
rcode = pacm->SetControlLineState(3);
if (rcode)
ErrorMessage<uint8_t>(PSTR("SetControlLineState"), rcode);
return rcode;
LINE_CODING lc;
lc.dwDTERate = 9600;
lc.bCharFormat = 0;
lc.bParityType = 0;
lc.bDataBits = 8;
rcode = pacm->SetLineCoding(&lc);
if (rcode)
ErrorMessage<uint8_t>(PSTR("SetLineCoding"), rcode);
return rcode;
USB Usb;
//USBHub Hub(&Usb);
ACMAsyncOper AsyncOper;
ACM Acm(&Usb, &AsyncOper);
Serial.begin( 9600 );
#if !defined(__MIPSEL__)
while (!Serial); // Wait for serial port to connect - used on Leonardo, Teensy and other boards with built-in USB CDC serial connection
#endif
Serial.println("Start");
if (Usb.Init() == -1)
Serial.println("OSCOKIRQ failed to assert");
delay( 200 );
Usb.Task();
if( Acm.isReady()) {
uint8_t rcode;
/* reading the keyboard */
if(Serial.available()) {
uint8_t data= Serial.read();
/* sending to the phone */
rcode = Acm.SndData(1, &data);
if (rcode)
ErrorMessage<uint8_t>(PSTR("SndData"), rcode);
}//if(Serial.available()...
delay(50);
String strNMEA;
/* reading the phone */
/* buffer size must be greater or equal to max.packet size */
/* it it set to 64 (largest possible max.packet size) here, can be tuned down
for particular endpoint */
uint8_t buf[64];
uint16_t rcvd = 64;
rcode = Acm.RcvData(&rcvd, buf);
if (rcode && rcode != hrNAK)
ErrorMessage<uint8_t>(PSTR("Ret"), rcode);
if( buf!="\0") { //more than zero bytes received
for(uint16_t i=0; i < rcvd; i++ ) {
//Serial.print((char)buf[i]); //printing on the screen
String strNMEA = ((char*)buf);
Serial.print(" strNMEA: ");
Serial.println(strNMEA);
strNMEA="";
delay(10);
}//if( Usb.getUsbTaskState() == USB_STATE_RUNNING..
