USB Host to MIDI
Is this what you are looking for?
gdsports:
MIDI USB to DIN Converter – HobbyTronics
I remember a thread from a couple of months back where someone was having problem with dropped notes on this device, I don't think he got it fixed in the end.
Pieter
Hello friends,
I'm new here in the forum and as well as you guys I also broke my brain enough to find out the error that prevented me from finishing this USB HOST communication problem and controlling my MS50g Zoom pedal.
The problem was corrected after I calmly read the error report and understood that it lacked to install the library referring to what was requested in the code.
PS: I had installed several libraries in an attempt to find some one that would make the code work properly and this generated conflicting libraries.
SOLUTION:
I removed the folders of libraries from the directory where they are installed, I restarted windows and reinstalled according to the error report generated in the Arduino IDE, where the report said that a certain library was missing there and installed it and then tried compile until it worked out and so the code compiled perfectly.
I hope I have helped you friends.
PS 2:
I used exactly the step-by-step of the Spider tutorial,
http://cyfrowogitarowo.pl/wp-content/uploads/2014/04/MIDI-USB-HOST-DIY-tutorial.pdf
