It seems I can not use the Layoutfiles for my mapping since they do not change the input to the correct char. They are the raw keycode if I under stand that correct.
(This would be the solution with the mapping, I did not include the layout since that did not work for me)
#include <Arduino.h>
#include "USB.h"
#include "USBHIDKeyboard.h"
#include "KeyboardLayout_DE.h"
char layout_US[] = {
'\0', '\x01', '\x02', '\x03', '\x04', '\x05', '\x06', '\a',
'\b', '\t', '\n', '\v', '\f', '\r', '\x0e', '\x0f',
'\x10', '\x11', '\x12', '\x13', '\x14', '\x15', '\x16', '\x17',
'\x18', '\x19', '\x1a', '\x1b', '\x1c', '\x1d', '\x1e', '\x1f',
'0', '1', '2', '3', '4', '5', '6', '7',
'8', '9', ':', ';', '<', '=', '>', '?',
'@', 'A', 'B', 'C', 'D', 'E', 'F', 'G',
'H', 'I', 'J', 'K', 'L', 'M', 'N', 'O',
'P', 'Q', 'R', 'S', 'T', 'U', 'V', 'W',
'X', 'Y', 'Z', '[', '\\', ']', '^', '_',
'`', 'a', 'b', 'c', 'd', 'e', 'f', 'g',
'h', 'i', 'j', 'k', 'l', 'm', 'n', 'o',
'p', 'q', 'r', 's', 't', 'u', 'v', 'w',
'x', 'y', 'z', '{', '|', '}', '~', '\x7f'};
char layout_DE[] = {
'8', '9', ':', '<', '<', '=', '>', '^',
'X', 'Z', 'Y', '[', '\\', ']', '`', '_',
'+', 'a', 'b', 'c', 'd', 'e', 'f', 'g',
'x', 'z', 'y', '{', '|', '}', '~', '\x7f'};
class EasyKeyboard
public:
EasyKeyboard()
keyboard.begin();
USB.begin();
~EasyKeyboard()
void typeDE(uint8_t *buffer, size_t buffersize)
for (int i = 0; i < buffersize; i++)
keyboard.print(layout_DE[buffer[i]]);
void newLine()
keyboard.println("");
void type(uint8_t *buffer, size_t buffersize)
keyboard.print(layout_US[buffer[i]]);
private:
USBHIDKeyboard keyboard;
For the secound method changing the files. That did not work for me either.
USBHIDKeyboard.h
Keyboard.h
Copyright (c) 2015, Arduino LLC
Original code (pre-library): Copyright (c) 2011, Peter Barrett
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#pragma once
#include "Print.h"
#include "USBHID.h"
#if CONFIG_TINYUSB_HID_ENABLED
#include "esp_event.h"
// Default keyboardlayout
// #include "KeyboardLayout.h"
#include "KeyboardLayout_US.h"
ESP_EVENT_DECLARE_BASE(ARDUINO_USB_HID_KEYBOARD_EVENTS);
typedef enum {
ARDUINO_USB_HID_KEYBOARD_ANY_EVENT = ESP_EVENT_ANY_ID,
ARDUINO_USB_HID_KEYBOARD_LED_EVENT = 0,
ARDUINO_USB_HID_KEYBOARD_MAX_EVENT,
} arduino_usb_hid_keyboard_event_t;
typedef union {
struct {
uint8_t numlock:1;
uint8_t capslock:1;
uint8_t scrolllock:1;
uint8_t compose:1;
uint8_t kana:1;
uint8_t reserved:3;
uint8_t leds;
} arduino_usb_hid_keyboard_event_data_t;
#define KEY_LEFT_CTRL 0x80
#define KEY_LEFT_SHIFT 0x81
#define KEY_LEFT_ALT 0x82
#define KEY_LEFT_GUI 0x83
#define KEY_RIGHT_CTRL 0x84
#define KEY_RIGHT_SHIFT 0x85
#define KEY_RIGHT_ALT 0x86
#define KEY_RIGHT_GUI 0x87
#define KEY_UP_ARROW 0xDA
#define KEY_DOWN_ARROW 0xD9
#define KEY_LEFT_ARROW 0xD8
#define KEY_RIGHT_ARROW 0xD7
#define KEY_BACKSPACE 0xB2
#define KEY_TAB 0xB3
#define KEY_RETURN 0xB0
#define KEY_ESC 0xB1
#define KEY_INSERT 0xD1
#define KEY_DELETE 0xD4
#define KEY_PAGE_UP 0xD3
#define KEY_PAGE_DOWN 0xD6
#define KEY_HOME 0xD2
#define KEY_END 0xD5
#define KEY_CAPS_LOCK 0xC1
#define KEY_F1 0xC2
#define KEY_F2 0xC3
#define KEY_F3 0xC4
#define KEY_F4 0xC5
#define KEY_F5 0xC6
#define KEY_F6 0xC7
#define KEY_F7 0xC8
#define KEY_F8 0xC9
#define KEY_F9 0xCA
#define KEY_F10 0xCB
#define KEY_F11 0xCC
#define KEY_F12 0xCD
#define KEY_F13 0xF0
#define KEY_F14 0xF1
#define KEY_F15 0xF2
#define KEY_F16 0xF3
#define KEY_F17 0xF4
#define KEY_F18 0xF5
#define KEY_F19 0xF6
#define KEY_F20 0xF7
#define KEY_F21 0xF8
#define KEY_F22 0xF9
#define KEY_F23 0xFA
#define KEY_F24 0xFB
#define LED_NUMLOCK 0x01
#define LED_CAPSLOCK 0x02
#define LED_SCROLLLOCK 0x04
#define LED_COMPOSE 0x08
#define LED_KANA 0x10
// Low level key report: up to 6 keys and shift, ctrl etc at once
typedef struct
uint8_t modifiers;
uint8_t reserved;
uint8_t keys[6];
} KeyReport;
class USBHIDKeyboard: public USBHIDDevice, public Print
private:
USBHID hid;
KeyReport _keyReport;
// contains the used keymap
const uint8_t *_asciimap;
public:
USBHIDKeyboard(void);
USBHIDKeyboard(const uint8_t *keymap);
void begin(void);
void end(void);
size_t write(uint8_t k);
size_t write(const uint8_t *buffer, size_t size);
size_t press(uint8_t k);
size_t release(uint8_t k);
void releaseAll(void);
void sendReport(KeyReport* keys);
//raw functions work with TinyUSB's HID_KEY_* macros
size_t pressRaw(uint8_t k);
size_t releaseRaw(uint8_t k);
void onEvent(esp_event_handler_t callback);
void onEvent(arduino_usb_hid_keyboard_event_t event, esp_event_handler_t callback);
// internal use
uint16_t _onGetDescriptor(uint8_t* buffer);
void _onOutput(uint8_t report_id, const uint8_t* buffer, uint16_t len);
#endif
USBHIDKeyboard.cpp:
Keyboard.cpp
#include "USBHID.h"
ESP_EVENT_DEFINE_BASE(ARDUINO_USB_HID_KEYBOARD_EVENTS);
esp_err_t arduino_usb_event_post(esp_event_base_t event_base, int32_t event_id, void *event_data, size_t event_data_size, TickType_t ticks_to_wait);
esp_err_t arduino_usb_event_handler_register_with(esp_event_base_t event_base, int32_t event_id, esp_event_handler_t event_handler, void *event_handler_arg);
static const uint8_t report_descriptor[] = {
TUD_HID_REPORT_DESC_KEYBOARD(HID_REPORT_ID(HID_REPORT_ID_KEYBOARD))
USBHIDKeyboard::USBHIDKeyboard(): hid(){
// Use US Keyboard as default
_asciimap = KeyboardLayout_en_US;
static bool initialized = false;
if(!initialized){
initialized = true;
hid.addDevice(this, sizeof(report_descriptor));
USBHIDKeyboard::USBHIDKeyboard(const uint8_t *keymap): hid(){
_asciimap = keymap;
if(!initialized){
initialized = true;
uint16_t USBHIDKeyboard::_onGetDescriptor(uint8_t* dst){
memcpy(dst, report_descriptor, sizeof(report_descriptor));
return sizeof(report_descriptor);
void USBHIDKeyboard::begin(){
hid.begin();
void USBHIDKeyboard::end(){
void USBHIDKeyboard::onEvent(esp_event_handler_t callback){
onEvent(ARDUINO_USB_HID_KEYBOARD_ANY_EVENT, callback);
void USBHIDKeyboard::onEvent(arduino_usb_hid_keyboard_event_t event, esp_event_handler_t callback){
arduino_usb_event_handler_register_with(ARDUINO_USB_HID_KEYBOARD_EVENTS, event, callback, this);
void USBHIDKeyboard::_onOutput(uint8_t report_id, const uint8_t* buffer, uint16_t len){
if(report_id == HID_REPORT_ID_KEYBOARD){
arduino_usb_hid_keyboard_event_data_t p;
p.leds = buffer[0];
arduino_usb_event_post(ARDUINO_USB_HID_KEYBOARD_EVENTS, ARDUINO_USB_HID_KEYBOARD_LED_EVENT, &p, sizeof(arduino_usb_hid_keyboard_event_data_t), portMAX_DELAY);
void USBHIDKeyboard::sendReport(KeyReport* keys)
hid_keyboard_report_t report;
report.reserved = 0;
report.modifier = keys->modifiers;
if (keys->keys) {
memcpy(report.keycode, keys->keys, 6);
memset(report.keycode, 0, 6);
hid.SendReport(HID_REPORT_ID_KEYBOARD, &report, sizeof(report));
size_t USBHIDKeyboard::pressRaw(uint8_t k)
uint8_t i;
if (k >= 0xE0 && k < 0xE8) {
// it's a modifier key
_keyReport.modifiers |= (1<<(k-0x80));
} else if (k && k < 0xA5) {
// Add k to the key report only if it's not already present
// and if there is an empty slot.
if (_keyReport.keys[0] != k && _keyReport.keys[1] != k &&
_keyReport.keys[2] != k && _keyReport.keys[3] != k &&
_keyReport.keys[4] != k && _keyReport.keys[5] != k) {
for (i=0; i<6; i++) {
if (_keyReport.keys[i] == 0x00) {
_keyReport.keys[i] = k;
if (i == 6) {
return 0;
//not a modifier and not a key
return 0;
sendReport(&_keyReport);
return 1;
size_t USBHIDKeyboard::releaseRaw(uint8_t k)
uint8_t i;
_keyReport.modifiers &= ~(1<<(k-0x80));
// Test the key report to see if k is present. Clear it if it exists.
// Check all positions in case the key is present more than once (which it shouldn't be)
if (0 != k && _keyReport.keys[i] == k) {
_keyReport.keys[i] = 0x00;
return 0;
return 1;
// press() adds the specified key (printing, non-printing, or modifier)
// to the persistent key report and sends the report. Because of the way
// USB HID works, the host acts like the key remains pressed until we
// call release(), releaseAll(), or otherwise clear the report and resend.
size_t USBHIDKeyboard::press(uint8_t k)
if (k >= 0x88) { // it's a non-printing key (not a modifier)
k = k - 0x88;
} else if (k >= 0x80) { // it's a modifier key
k = 0;
} else { // it's a printing key
k = _asciimap[k];
if (!k) {
return 0;
if (k & 0x80) { // it's a capital letter or other character reached with shift
_keyReport.modifiers |= 0x02; // the left shift modifier
k &= 0x7F;
return pressRaw(k);
// release() takes the specified key out of the persistent key report and
// sends the report. This tells the OS the key is no longer pressed and that
// it shouldn't be repeated any more.
size_t USBHIDKeyboard::release(uint8_t k)
k = k - 0x88;
k = 0;
k = _asciimap[k];
if (!k) {
return 0;
_keyReport.modifiers &= ~(0x02); // the left shift modifier
k &= 0x7F;
return releaseRaw(k);
void USBHIDKeyboard::releaseAll(void)
_keyReport.keys[0] = 0;
_keyReport.keys[1] = 0;
_keyReport.keys[2] = 0;
_keyReport.keys[3] = 0;
_keyReport.keys[4] = 0;
_keyReport.keys[5] = 0;
_keyReport.modifiers = 0;
size_t USBHIDKeyboard::write(uint8_t c)
uint8_t p = press(c); // Keydown
release(c); // Keyup
return p; // just return the result of press() since release() almost always returns 1
size_t USBHIDKeyboard::write(const uint8_t *buffer, size_t size) {
size_t n = 0;
while (size--) {
if (*buffer != '\r') {
if (write(*buffer)) {
n++;
buffer++;
return n;
#endif /* CONFIG_TINYUSB_HID_ENABLED */
KeyboardLayout_US.h
#pragma once
const uint8_t KeyboardLayout_en_US[128] PROGMEM
0x00, // NUL
0x00, // SOH
0x00, // STX
0x00, // ETX
0x00, // EOT
0x00, // ENQ
0x00, // ACK
0x00, // BEL
0x2a, // BS Backspace
0x2b, // TAB Tab
0x28, // LF Enter
0x00, // VT
0x00, // FF
0x00, // CR
0x00, // SO
0x00, // SI
0x00, // DEL
0x00, // DC1
0x00, // DC2
0x00, // DC3
0x00, // DC4
0x00, // NAK
0x00, // SYN
0x00, // ETB
0x00, // CAN
0x00, // EM
0x00, // SUB
0x00, // ESC
0x00, // FS
0x00, // GS
0x00, // RS
0x00, // US
0x2c, // ' '
0x1e|SHIFT, // !
0x34|SHIFT, // "
0x20|SHIFT, // #
0x21|SHIFT, // $
0x22|SHIFT, // %
0x24|SHIFT, // &
0x34, // '
0x26|SHIFT, // (
0x27|SHIFT, // )
0x25|SHIFT, // *
0x2e|SHIFT, // +
0x36, // ,
0x2d, // -
0x37, // .
0x38, // /
0x27, // 0
0x1e, // 1
0x1f, // 2
0x20, // 3
0x21, // 4
0x22, // 5
0x23, // 6
0x24, // 7
0x25, // 8
0x26, // 9
0x33|SHIFT, // :
0x33, // ;
0x36|SHIFT, // <
0x2e, // =
0x37|SHIFT, // >
0x38|SHIFT, // ?
0x1f|SHIFT, // @
0x04|SHIFT, // A
0x05|SHIFT, // B
0x06|SHIFT, // C
0x07|SHIFT, // D
0x08|SHIFT, // E
0x09|SHIFT, // F
0x0a|SHIFT, // G
0x0b|SHIFT, // H
0x0c|SHIFT, // I
0x0d|SHIFT, // J
0x0e|SHIFT, // K
0x0f|SHIFT, // L
0x10|SHIFT, // M
0x11|SHIFT, // N
0x12|SHIFT, // O
0x13|SHIFT, // P
0x14|SHIFT, // Q
0x15|SHIFT, // R
0x16|SHIFT, // S
0x17|SHIFT, // T
0x18|SHIFT, // U
0x19|SHIFT, // V
0x1a|SHIFT, // W
0x1b|SHIFT, // X
0x1c|SHIFT, // Y
0x1d|SHIFT, // Z
0x2f, // [
0x31, // bslash
0x30, // ]
0x23|SHIFT, // ^
0x2d|SHIFT, // _
0x35, // `
0x04, // a
0x05, // b
0x06, // c
0x07, // d
0x08, // e
0x09, // f
0x0a, // g
0x0b, // h
0x0c, // i
0x0d, // j
0x0e, // k
0x0f, // l
0x10, // m
0x11, // n
0x12, // o
0x13, // p
0x14, // q
0x15, // r
0x16, // s
0x17, // t
0x18, // u
0x19, // v
0x1a, // w
0x1b, // x
0x1c, // y
0x1d, // z
0x2f|SHIFT, // {
0x31|SHIFT, // |
0x30|SHIFT, // }
0x35|SHIFT, // ~
0 // DEL
KeyboardLayout_DE.h:
* German keyboard layout.
#pragma once
extern const uint8_t KeyboardLayout_de_DE[128] PROGMEM =
0x00, // NUL
0x00, // SOH
0x00, // STX
0x00, // ETX
0x00, // EOT
0x00, // ENQ
0x00, // ACK
0x00, // BEL
0x2b, // TAB Tab
0x28, // LF Enter
0x00, // VT
0x00, // FF
0x00, // CR
0x00, // SO
0x00, // SI
0x00, // DEL
0x00, // DC1
0x00, // DC2
0x00, // DC3
0x00, // DC4
0x00, // NAK
0x00, // SYN
0x00, // ETB
0x00, // CAN
0x00, // EM
0x00, // SUB
0x00, // ESC
0x00, // FS
0x00, // GS
0x00, // RS
0x00, // US
0x2c, // ' '
0x1e|SHIFT, // !
0x1f|SHIFT, // "
0x31, // #
0x21|SHIFT, // $
0x22|SHIFT, // %
0x23|SHIFT, // &
0x31|SHIFT, // '
0x25|SHIFT, // (
0x26|SHIFT, // )
0x30|SHIFT, // *
0x30, // +
0x36, // ,
0x38, // -
0x37, // .
0x24|SHIFT, // /
0x27, // 0
0x1e, // 1
0x1f, // 2
0x20, // 3
0x21, // 4
0x22, // 5
0x23, // 6
0x24, // 7
0x25, // 8
0x26, // 9
0x37|SHIFT, // :
0x36|SHIFT, // ;
0x32, // <
0x27|SHIFT, // =
0x32|SHIFT, // >
0x2d|SHIFT, // ?
0x14|ALT_GR, // @
0x04|SHIFT, // A
0x05|SHIFT, // B
0x06|SHIFT, // C
0x07|SHIFT, // D
0x08|SHIFT, // E
0x09|SHIFT, // F
0x0a|SHIFT, // G
0x0b|SHIFT, // H
0x0c|SHIFT, // I
0x0d|SHIFT, // J
0x0e|SHIFT, // K
0x0f|SHIFT, // L
0x10|SHIFT, // M
0x11|SHIFT, // N
0x12|SHIFT, // O
0x13|SHIFT, // P
0x14|SHIFT, // Q
0x15|SHIFT, // R
0x16|SHIFT, // S
0x17|SHIFT, // T
0x18|SHIFT, // U
0x19|SHIFT, // V
0x1a|SHIFT, // W
0x1b|SHIFT, // X
0x1d|SHIFT, // Y
0x1c|SHIFT, // Z
0x25|ALT_GR, // [
0x2d|ALT_GR, // bslash
0x26|ALT_GR, // ]
0x00, // ^ not supported (requires dead key + space)
0x38|SHIFT, // _
0x00, // ` not supported (requires dead key + space)
0x04, // a
0x05, // b
0x06, // c
0x07, // d
0x08, // e
0x09, // f
0x0a, // g
0x0b, // h
0x0c, // i
0x0d, // j
0x0e, // k
0x0f, // l
0x10, // m
0x11, // n
0x12, // o
0x13, // p
0x14, // q
0x15, // r
0x16, // s
0x17, // t
0x18, // u
0x19, // v
0x1a, // w
0x1b, // x
0x1d, // y
0x1c, // z
0x24|ALT_GR, // {
0x32|ALT_GR, // |
0x27|ALT_GR, // }
0x30|ALT_GR, // ~
0x00 // DEL
KeyboardLayout.h:
KeyboardLayout.h
This file is not part of the public API. It is meant to be included
only in Keyboard.cpp and the keyboard layout files. Layout files map
ASCII character codes to keyboard scan codes (technically, to USB HID
Usage codes), possibly altered by the SHIFT or ALT_GR modifiers.
Non-ACSII characters (anything outside the 7-bit range NUL..DEL) are
not supported.
== Creating your own layout ==
In order to create your own layout file, copy an existing layout that
is similar to yours, then modify it to use the correct keys. The
layout is an array in ASCII order. Each entry contains a scan code,
possibly modified by "|SHIFT" or "|ALT_GR", as in this excerpt from
the Italian layout:
0x35, // bslash
0x30|ALT_GR, // ]
0x2e|SHIFT, // ^
Do not change the control characters (those before scan code 0x2c,
corresponding to space). Do not attempt to grow the table past DEL. Do
not use both SHIFT and ALT_GR on the same character: this is not
supported. Unsupported characters should have 0x00 as scan code.
For a keyboard with an ISO physical layout, use the scan codes below:
|35 |1e |1f |20 |21 |22 |23 |24 |25 |26 |27 |2d |2e |BackSp |
| Tab |14 |1a |08 |15 |17 |1c |18 |0c |12 |13 |2f |30 | Ret |
|CapsL |04 |16 |07 |09 |0a |0b |0d |0e |0f |33 |34 |31 | |
|Shi.|32 |1d |1b |06 |19 |05 |11 |10 |36 |37 |38 | Shift |
|Ctrl|Win |Alt | |AlGr|Win |Menu|Ctrl|
The ANSI layout is identical except that key 0x31 is above (rather
than next to) Return, and there is not key 0x32.
Give a unique name to the layout array, then declare it in Keyboard.h
with a line of the form:
extern const uint8_t KeyboardLayout_xx_YY[];
== Encoding details ==
All scan codes are less than 0x80, which makes bit 7 available to
signal that a modifier (Shift or AltGr) is needed to generate the
character. With only one exception, keys that are used with modifiers
have scan codes that are less than 0x40. This makes bit 6 available
to signal whether the modifier is Shift or AltGr. The exception is
0x64, the key next next to Left Shift on the ISO layout (and absent
from the ANSI layout). We handle it by replacing its value by 0x32 in
the layout arrays.
#pragma once
#define SHIFT 0x80
#define ALT_GR 0xc0
#define ISO_KEY 0x64
#define ISO_REPLACEMENT 0x32
main.cpp:
#include "USB.h"
#include "USBHIDMouse.h"
#include "USBHIDKeyboardMod.h"
USBHIDKeyboardMod keyboard(KeyboardLayout_de_DE);
keyboard.begin();
USB.begin();
delay(2000);
String inputString = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz!\"#$%&'()*+,-./:;<=>?@[\\]^_``{|}~";
// keyboard.printChars();
keyboard.print(inputString);
The expected result would be:
ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz!"#$%&'()+,-./:;<=>?@[]^_``{|}~
But I get :
ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz!"#$%&'()+,-./:;#='?/" + It locks my screen
So I guess there is still a small error since most of the output is correct except the last ones.
Do you may know why this problem occures? Does the lib work correct with an arduino?
Thank you for your help so far
