Hello,
I hope that I post this at the right subforum, otherwise please let me know.
Attached you will find a pdf of a schematic I made. The problem I am having is that the device is not seen as a Arduino Leonardo after uploading the Caterina bootloader over ISP and connecting it with the usb connector.
A few notes:
- There is also a resistor of 10k ohm between Vcc and PE2(HWB), I forgot to include this in the picture.
- There are connections in the schematic that I left out of the picture. I did this because they are NOT connected on the physical PCB as well.
- When the usb connector is plugged in to a computer, it looks like the ATMega32u4 resets itself four times in a row before windows shows up the error message in which it says the usb device is not recognized.
- If I connect the device to a power-only usb cable, it does not seem to reset itself.
- In device manager it says the error code is 43. The usb device descriptor could not be retrieved.
Things I already have tried:
- I put two resistors of 22 ohm in series with the D+ and D- of the usb data wires
- I checked if there were any shorts, but I could not find any.
- I tried different fuse bits.
My questions:
- Which fuse bits should I use for this setup with an external 16MHz crystal?
- Any idea what I could have done wrong that causes the USB connection to fail?
I look forward to your replies and hope someone is willing to help me! (Thanks in advance)
