Long story short I need the Arduino to control some sensors and power a fan. (12v or 5v). I don't need a lot of power (its just to ventilate some plants to remove humidity).
I cant use a MOSFET or Arduino relay shield as I need the pins for the sensors.
I cant use a normal relay as I don't want to make "custom wires" for fire hazards. (I could rip a USB cable plug it into a normal relay and that's all) but I would rather not.
So I was wondering if there is any better option such as
a) USB-powered relay, so instead of "feeding" the relay with a + and - wires you just plug a USB cable.
b) You can power a USB relay with an Arduino/raspberry pi power source
What model Arduino are you using?
If you use a 5V supply you can power a 5V Arduino controller and a 5V relay off the same source.
So how do you envisage connecting up the relay or switching device to the controller?
