USB Raw HID Interfacing - Library to Arduino?
I'm working with the Teensy2.0++ from PJRC (http://www.pjrc.com/store/teensypp_pins.html) and using WinAVR to compile the RAW HID example, managed to get it to communicate back and forth with my program.
I am trying to interface this with the LEDCONTROL library which is available in the Arduino interface but cannot seem to bring the RAW HID library over to the Arduino environment (http://www.pjrc.com/teensy/rawhid.html)
Are there any sharp C programmer types that can assist? I'm a long-time Pascal (Borland Delphi 7) programmer trying to learn my way through C
Thanks in advance!
I am kinda new to arduino, but so far, inporting my own code, I needed to make them 'classes' in order to integrate. So 3 choices:
  1. simply make the hid code cpp, turn them into classes (or make a arduino lib out of them)
  2. better would be to copy the teensy code under 'cores' and add a new rawhid. Are you sure kb/mouse(hid) wont work for you?
  3. write a small 'wrapper' class to act as glue between arduino and hid code.
I would take the option2 route myself.
Also I did not see a lot of write-ups about such things either. The correct process for porting code, incorporating other code into arduino. So its a slow process for me still.
